| Re: 06 CBR600rr Drains battery Update: I ran the following Test:
(Specification for maximum battery charging voltage with the engine at 4,000 rpm is 13 to 15.5 VDC)
Mine read 13.7
(Specification for stator coil resistance is .2 to 2.5 Ohms of resistance.
Mine read .3
(Specification for stator coil shorts test is no continuity)
Mine verified no continuity
(Specification for stator coil AC voltage output is at least 45 VAC at 4,000 rpm)
It read 45 VAc but I did notice that when I disconnected the three pin white plastic coupler with the three yellow wires in it to perform this test I only had a few seconds (~10) as the bike started draining the battery (Light dims and the bike starts to stall). As soon as I reconnect the coupler the bike was fine (Light strong as ever)
I will run the rectifer diode tests tommorow; the wires are a little difficult to get to. |
