1993 F2 will ONLY start in neutral!
Old 07-21-2008, 9:02 PM
Bike(s): 1993 CBR600 F2
Rep: baker0408 is on a distinguished road (10)
I just purchased a 1993 CBR600f2. The bike runs mint, but the only issue I am having is that will only start in neutral. Being a new rider, it makes me a little nervous since if i stall out then i have to get the make back in the neutral then back into gear. I don't know if this is something that can be easily fixed, but I can't imagine this is normal and/or safe.
Let me know if I can fix this! Thanks!!!
baker0408 is offline
View baker0408's Profile View baker0408's Gallery Find More Posts by baker0408
Old 07-21-2008, 9:30 PM
Bike(s): dirt or street.. I like both
Rep: spyonu2007 is on a distinguished road (15)
Re: 1993 F2 will ONLY start in neutral!
Kick stand up or down?
spyonu2007 is offline
View spyonu2007's Profile View spyonu2007's Gallery Find More Posts by spyonu2007
Old 07-21-2008, 9:38 PM
It will start in neutral with it up or down. It will die if it is put into gear with the kick stand down. When trying to start while in gear (kickstand up) the starter does not even make a noise. (it is like the key is not on)
Bike(s): 2006 blue and yellow 1krr
Rep: ldavis is on a distinguished road (20)
that's the first question i was going to ask.. and
are you holding the clutch in.. ?
start simple and go from there..
ldavis is offline
View ldavis's Profile View ldavis's Gallery Find More Posts by ldavis My Map Location
Old 07-21-2008, 9:42 PM
yes I am holding the clutch in...well when trying to start in gear...no need when in neutral, b/c it fires right up. it is like there is not electrical connection to the starter once the bike is in gear.
Old 07-21-2008, 9:59 PM
Abandon All Hope
Doomwitha929's Avatar
Bike(s): 2000 929
Rep: Doomwitha929 is on a distinguished road (27)
clutch switch
Doomwitha929 is offline
View Doomwitha929's Profile View Doomwitha929's Gallery Find More Posts by Doomwitha929
Old 07-21-2008, 10:01 PM
I am not sure what you mean by "clutch switch"?
Old 07-21-2008, 10:12 PM
Abandon All Hope
Bike(s): 2000 929
is there a little electrical switch in the clutch lever assembly? A clutch switch keeps the bike from starting when the bike is in gear unless the lever is pulled.
Old 07-21-2008, 10:16 PM
Since the bike will not start when the clutch is in, does this mean it is off or damaged? How do I check / find it?
Old 07-21-2008, 10:23 PM
Abandon All Hope
Bike(s): 2000 929
You disconnect the switch and see if the bike starts normally. If not then you jump the connector (to the bikes harness not to the switch) with a wire and see if it starts.
Old 07-22-2008, 3:09 AM
rokitt51's Avatar
Rep: rokitt51 is on a distinguished road (30)
I cant understand why you think that is not safe??????
rokitt51 is offline
Old 07-22-2008, 3:38 AM
Bike(s): 2007 Repsol & 2004 Mille R
Rep: MCR001 is on a distinguished road (23)
sounds like the little sensor switch - which is located at the kickstand, is faulty.
What happens is the saftey switch works when the kickstand is down - stops any starting unless in neutral. there is really no fix other than replacing it. It connects back to the relay switches and to take off the kickstand, easy job but time consuming.
MCR001 is offline
View MCR001's Profile View MCR001's Gallery Find More Posts by MCR001 My Map Location
Old 07-22-2008, 2:11 PM
Abandon All Hope
Bike(s): 2000 929
if the stand switch was bad you could still put it in gear with the clutch pulled.
I think... I'm fairly confused at this point.
Old 07-22-2008, 3:00 PM
the thing is even if u pull the clutch in and put down the stand it will cut out, its purly safety issue - to stop u riding with the stand down.
MCR001 is offline
Old 07-22-2008, 3:07 PM
  #15
Bike(s): 1998 CBR900rr fireblade
Rep: Charles486 is on a distinguished road (10)
Test and/or replace the clutch switch, my money says theres your problem.
Charles486 is offline
View Charles486's Profile View Charles486's Gallery Find More Posts by Charles486
Old 07-22-2008, 3:09 PM
  #16
rokitt51's Avatar
rokitt51 is offline
Old 07-22-2008, 4:26 PM
  #17
Bike(s): P.D.Q. '93 CBR 600F2
Rep: Rickracer is on a distinguished road (10)
Correction: Running, in gear, clutched pulled in, if you put the kickstand down, it will kill the motor. Kickstand down, in gear, clutch pulled in, it will not start.
Rickracer is offline
View Rickracer's Profile View Rickracer's Gallery Find More Posts by Rickracer
Old 07-22-2008, 8:41 PM
  #18
Abandon All Hope
Bike(s): 2000 929
yeah the clutch has to be in and stand UP to start in gear.
OK, stand up clutch IN will it start while in gear?
It seems to me if it was the stand switch then once its started in N if you let the clutch out in gear it would shut off. If the stand swtch is bad it shouldnt run no matter what.
Old 07-22-2008, 8:49 PM
  #19
lanbrown's Avatar
Rep: lanbrown will become famous soon enough (57)
Originally Posted by Doomwitha929 View Post
clutch switch
You are correct, clutch switch is what I say as well.
If he tries to put the bike in gear with it down, it dies. That tells me the sidestand switch is fine. The bike knows the position of it.
lanbrown is offline
Old 07-22-2008, 8:52 PM
  #20
Bike(s): 900fireblade, RGV250R, TL1000R, YZWR250
Rep: fireblake is on a distinguished road (10)
ive had this same prob and it was the clutch switch if it was the stand switch it would not cut out when you put the stand down after started and put in gear.
fireblake is offline
View fireblake's Profile View fireblake's Gallery Find More Posts by fireblake
Old 07-23-2008, 7:13 PM
  #21
Thank you all sooo much! I am thinking it is the clutch switch for sure!
How (and difficult) is this to replace/repair? Is it a part that should be readily available and where could I find one? I have the service manual, but it just shows where it is located, not how to replace it.
Thanks again!
Old 07-23-2008, 8:44 PM
  #22
lanbrown's Avatar
Honda probably just sells the lever as a complete piece. So you will probably have to replace it as a unit.
A second option would be to install a pressure switch. This is required on some aftermarket levers; brake and clutch.
lanbrown is offline
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 3:12 PM.
