where is the idle valve \ adjuster for a honda cbr600f3? - Honda Motorcycles - FireBlades.org
post #1 of 7 Old 08-09-2008, 4:33 AM Thread Starter
17%
i can't seem to find it. my bike isn't idling correctly (or at all). it can start when it give it gas but as soon as i let the gas go, it'll stop running.
the only thing i can think of is to look for the idle valve and adjust it.
any suggestions are appreciated
17% is offline
post #2 of 7 Old 08-09-2008, 4:47 AM
Images: 1
Reputation Power: 9
Re: where is the idle valve \ adjuster for a honda cbr600f3?
It's on the middle/left(clutch) side of the bike and should be sticking out through a hole in the fairing/tail section. It should be near/below the fuel on/off/reserve petcock.
exit90a is offline
post #3 of 7 Old 08-09-2008, 12:42 PM Thread Starter
17%
it seems like theres no difference when i adjust this screw at all. to make it idling higher, should i be turning it clockwise or counter clockwise\anticlockwise?
17% is offline
post #4 of 7 Old 08-09-2008, 3:04 PM
Reputation Power: 9
Clockwise. It's actually the idle stop screw, somebody may have backed it off.
Rickracer is offline
post #5 of 7 Old 08-10-2008, 1:43 AM Thread Starter
17%
so i've been trying to screw it clockwise for a bit. it doesn't seem to make my idle go higher. when i do it the other way, it doesn't have any effect either.
has anybody had any experience with this?
17% is offline
post #6 of 7 Old 08-10-2008, 9:54 AM
Reputation Power: 9
It's actually a cable attached to the stop screw. I'm not sure how it's attached, but it may have come loose, or if someone has turned it too far counterclockwise, it will come out of the part it's threaded into. Sounds like you may need to pull the tank and airbox to see what's going on.
post #7 of 7 Old 08-11-2008, 11:43 PM Thread Starter
17%
thanks rickracer, ill check that out. it seems very plausible. ill update if this solves the problem.
17% is offline
Human Verification
Search tags for this page
1995 cvr 600 idle control
1997 cbr 600 f3 idle tube left side
96 honda cbr 600 f3 clutch adjustment screw
97 cbr 600 idle adjustment
97 cbr600 idle adjust
97 honda cbr600 idle screw
honda trx 300 idle clockwise or counter clockwise
how to clean the idle adjuster on a 1998cbr 600
idle screw on cbr 600 f3
where does 1997 honda cbr 600 idle adjustment cable screw
BIKE WONT IDLE RIGHT. NOR RUN FOR LONG THINK IT IS THE STATOR AND RECTIFIER. JordanCBRF3SJ Honda CBR 600 2 05-05-2008 7:42 PM
Spies and Mladin at it again... where is Honda TKDmasterZ Road Racing: Professional 8 03-09-2008 9:11 PM
cbr600f3 tank overflow valve seebeegeebee Honda CBR 600 0 11-06-2005 2:28 PM
is my damper adjuster broke? Soupy Honda FireBlade 8 07-01-2003 5:46 AM
Where is the best price for Devil pipes? MartDog Honda FireBlade 3 06-16-2003 2:56 AM
