How thin a Chain Can I go on my 1996 CBR600FT?
Old 01-22-2009, 7:47 AM
Bike(s): in Situ Guys!
Rep: marty_400 is on a distinguished road (13)
Hiya All,
Had a chat with a local bike shop, who checked:
1995/96 cbr6 530 Chain as Std
1997/98 cbr6 525 Chain as Std
Can I convert to a 520 chain on my 1996 CBR600FT?
Are there any issues with with this?
Hope you can advise
Cheers
Martin
marty_400 is offline
View marty_400's Profile View marty_400's Gallery Find More Posts by marty_400
Old 01-22-2009, 5:25 PM
lanbrown's Avatar
Rep: lanbrown is a jewel in the roughlanbrown is a jewel in the roughlanbrown is a jewel in the rough (268)
Re: How thin a Chain Can I go on my 1996 CBR600FT?
People use the 520 chains on 1000cc bikes all of the time. Just buy a brand name quality chain and sprockets.
lanbrown is offline
Old 01-22-2009, 5:38 PM
Thanks LB,
I thought so, but wanted to check! Am I right in thinking the 520 chain will be substantially thinner than the 530 chain?
If I stick a scottoiler on her as well, will the chain last ok?
I can't really see myself lashing the 600. She'll be my comfy sofa bike - the 400cc will be the one to get the good seeing to!
Hope you can advise!
Cheers
Martin
Old 01-22-2009, 5:40 PM
firebladeking's Avatar
Bike(s): 2008 CBR1000rr Fireblade
Rep: firebladeking will become famous soon enough (55)
you can use a 520 chain, but remember it will wear quicker, so you'll be replacing the chain and sprockets sooner.
IMO you wont even feel the difference, rather put the recommended size chain and replace it less
firebladeking is offline
View firebladeking's Profile View firebladeking's Gallery Find More Posts by firebladeking My Map Location
Old 01-22-2009, 5:41 PM
lanbrown's Avatar
The 520 chain is not all that weak. Check the tensile rating between the two.
lanbrown is offline
Old 01-22-2009, 5:50 PM
rokitt51's Avatar
Bike(s): 97 YZF1000, 02 954
Rep: rokitt51 will become famous soon enoughrokitt51 will become famous soon enough (111)
, Ive went to 520 on all my bikes but 2. I have snapped one chain on one of my bikes b4 (RC51), and that had to just be the chain (530 DID). My sister uses 520 on her strip bike and its a ZX12 with built motor runnin laughin gas.
rokitt51 is offline
View rokitt51's Profile View rokitt51's Gallery Visit rokitt51's homepage! Find More Posts by rokitt51
Old 01-22-2009, 5:56 PM
DID X-ring Chains
the 530 is 4.7mm wider
the plates are 0.4mm thicker
the tensile strength is 7.6KN more.
the 530 is allot stronger and harder wearing than the 520.
the 520 will wear quicker but it will give you 0.5KG weight saving, and slightly quicker acceleration due to less rotating mass
Old 01-22-2009, 6:29 PM
Wow, thanks for all the advice guys!
I'll stick a scottoiler on as well - so hopefully that will improve the "chain Life" issue.
I'll see the difference in cost between the chains and go from there
Cheers
Martin
Old 01-22-2009, 11:07 PM
lanbrown's Avatar
Don't forget the sprockets.
lanbrown is offline
Old 01-23-2009, 1:31 PM
Stop Snitchin
CBR929RE's Avatar
Bike(s): 01 R/B 929
Rep: CBR929RE has much to be proud ofCBR929RE has much to be proud ofCBR929RE has much to be proud ofCBR929RE has much to be proud ofCBR929RE has much to be proud ofCBR929RE has much to be proud ofCBR929RE has much to be proud ofCBR929RE has much to be proud of (1088)
as long as you do proper maintenance it should last many thousands of miles. its only a 1996 CBR600, not a ton of power by any means. any of the current good quality (DID, RK, EK) 520 chains will be perfectly fine.
Cheers
Martin
you don't need a Scottoiler. regular cleaning lubing just like any other chain and you'll be good. Nothing wrong with a Scottoiler if you want to use one.
and 520 is the pitch of the chain not width. it can equate to a slightly thinner chain.
CBR929RE is offline
Old 01-23-2009, 3:12 PM
I think you'll find the "5" is the pitch and the "20", "25", or "30" is the thickness.
520/530 Chain Identification - CycleChaos
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 4:06 PM.
