RE:Scottoiler - can I put in along the "Grab handle" on the LHS Pedal rest?
Old 01-24-2009, 5:28 AM
Bike(s): in Situ Guys!
Rep: marty_400 is on a distinguished road (13)
RE:Can you put the Scottoiler reseviour in a place that gets all covered in cack?
Hiya All,
I've had a look around my 1996 CBR600FT for a place to put the Scottoiler. (My CBr is one of those ones where it is all covered in Fairing, and the seat dosen't come off with a key, you need to take the side panels off, then spanner off the seat bolts! I can't do that every week, to check the scottoiler level - and if I don't check regularyly, i bet I'll forget!)
The only place I can see to put the scottoiler, is along the steel frame, under the rear wheel arch. However that part of the frame is (Just found out last night) Covered in Cack! Keep forgetting to wash under the fairing.
Couple of questions:
1. Can you put the Scottoiler reseviour in a place that gets all covered in cack?
2. If I put electrical tape over the "Refill" hole - is that enough to stop dirt getting into the system, when I eventually have to refill? (Ie I'll take off the tape, fill up, then put some more on?)
3. Are there any other problems with putting the scottoiler there?
4. Am I better off just getting a "touring" Scottoiler tank - which fits behind the reg plate - or is that overkill, and just really heavy?
Hope you can Advise!
Cheers
Martin
marty_400 is offline
View marty_400's Profile View marty_400's Gallery Find More Posts by marty_400
Old 01-24-2009, 5:31 AM
Hiya All,
I've just had a brain wave! For my 1996 FT - Can I put the scottoiler behind that Grab handle" on the LHS Pedal rest? Hope you can advise!
Cheers
Martin
Old 01-24-2009, 5:48 AM
Sideshow bob's Avatar
Bike(s): 1995 CBR900rr, 1990 GSX-R 750, project Blade
Rep: Sideshow bob has a reputation beyond reputeSideshow bob has a reputation beyond reputeSideshow bob has a reputation beyond reputeSideshow bob has a reputation beyond reputeSideshow bob has a reputation beyond reputeSideshow bob has a reputation beyond reputeSideshow bob has a reputation beyond reputeSideshow bob has a reputation beyond reputeSideshow bob has a reputation beyond reputeSideshow bob has a reputation beyond reputeSideshow bob has a reputation beyond repute (2934)
Send a message via MSN to Sideshow bob
Re: Scottoiler - can I put in along the "Grab handle" on the LHS Pedal rest?
as long as it tilts slightly forward......
.... you can put it anywhere...
will post some piccy's of ours if you like... but it can be mounted anything from vertical to nearly horizontal, it's really a case of where you wanna put it
As long as I fall, I don't hit the ground. As long as I fall, I'm safe & sound.
Sideshow bob is offline
View Sideshow bob's Profile View Sideshow bob's Gallery Find More Posts by Sideshow bob
Old 01-24-2009, 5:53 AM
Re: Can you put the Scottoiler reseviour in a place that gets all covered in cack?
Originally Posted by marty_400 View Post
Hiya All,
yes... it'll work even if cacky
& there should be a rubber bung with a breather that fits into the little hole
Old 01-24-2009, 7:26 PM
Hiya Side show,
Some pictures would be fab.
I'm just scratching my head about the best place to out the reseviour on the FT! in view would be good, but not if it can get knocked easily, or gets completely covered in cack all the time.
Cheers
MArtin
Old 01-25-2009, 7:53 AM
Here you go marty
I've always mounted them the same basic way...
The oiler unit under seat or behind side panel
On my Duke it just hung from the sub frame
on the blade its behind RH side panel and accesed from pillion seat
The feed I always run behind frame to swing arm
on most I've run it under swingarm.. altho the duke was even easier.. it runs along breakline chanel in hugger
The breather I always tie to the frame
the Vacuum line i run along the wireing harness
All were spliced into the petrol tap vacuum line or onto the carb manifold..
on both mine and Loopys they are totally hidden.. & the only problem I've found is on the Duke (becouse it right above the exhaust it gets warm.. the oil thins.. so I have had to set it alot lower than on the blade)
Name:	748 oiler.jpg
ID:	34345  Click image for larger version
Name:	748 nozzle.jpg
ID:	34346  Click image for larger version
Name:	Blade oiler.jpg
Old 01-25-2009, 7:31 PM
Thats for that SSB!
The Duke looks fab, even without her kit on! 8)
Old 01-25-2009, 7:59 PM
firebladeking's Avatar
Bike(s): 2008 CBR1000rr Fireblade
Rep: firebladeking will become famous soon enough (55)
Hey SSB, did you misplace a can of coke while fitting the scottsoiler? it's next to the shock if you still looking for it
firebladeking is offline
View firebladeking's Profile View firebladeking's Gallery Find More Posts by firebladeking My Map Location
Old 01-26-2009, 8:16 AM
The best I've seen was a eletric Blue Kwak - with a Matching rebull can wrapped around the remote resevouir!
Old 01-26-2009, 2:52 PM
Got it....
Damn... it well flat!
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 8:36 AM.
