Hiss programming 600rr - Honda Motorcycles - FireBlades.org
post #1 of 14 Old 04-13-2009, 12:16 PM Thread Starter
Images: 5
Hello all!! I've been searching the site for programming instructions on adding new keys for my 600rr, already managed to get the procedure out the workshop manual for programming but i'm not clear on the set up of using the harness (home made!!) I have 2 lengths of cable, a 1k resistor soldered on the + side, croc clips on one end for connecting to the battery. The other end i'm not sure about, does it connect to the pulse generator male plug or the female plug connecting to the bikes wiring harness? Is the white or white/yellow cable the positive or negative? Any help gratefull!!
Cheers, Mark.
Cronin is offline
post #2 of 14 Old 04-19-2009, 12:48 PM Thread Starter
Images: 5
Re: Hiss programming 600rr
Hope this helps some of you!!
Taken from the Haynes manual, this procedure along with the home made cable (photo's in my gallery) worked a treat on my 03 600rr. On the bikes wiring harness the Yellow wire should be used as the positive 12v+ dc and the white/yellow 12v -
1. Obtain a new transponder key.
2. Grind the key in accordance with the shape of the original key.
3. Apply 12V battery voltage to the ignition pulse generator lines of the engine control module (ECM) using the special tool (page 20-5).
4. Turn the ignition switch ON with the original key. The immobiliser indicator comes on and it remains on.
*The code of the original key is recognised by the ECM.
*If there is any problem in the immobiliser system, the system will enter the diagnostic mode and the indicator will remain on for approx. ten seconds, then it will indicate the diagnostic code (page 20-5).
5. Disconnect the red clip of the inspection adaptor from the battery positive (+) terminal for two seconds or more, then connect it again. The indicator remains on for approx. two seconds, then it blinks four times repeatedly.
*The immobiliser system (HISS) enters the registration mode. Registrations of all key except the original key inserted in the ignition switch are cancelled. (Registration of the lost key or spare key is cancelled.)
NOTE:
The spare key must be registered again.
6. Turn the ignition switch OFF and remove the key.
7. Turn the ignition switch ON with a new key or the spare key. (Never use the key registered in previous step.) The indicator comes on for two seconds, then it blinks four times repeatedly.
*The new key or spare key is registered in the ECM.
*If there is any problem in the registration, the system will enter the diagnostic mode and the indicator will remain on for approx. ten seconds, then it will indicate the diagnostic code (page 20-6).
CAUTION:
Keep the other transponder key away from the immobiliser receiver more than 50mm (2.0 in).
8. Repeat the steps 6 and 7 when you continuously register the other new key.
NOTE:
The ECM can store up to four key codes. (The four keys can be registered.)
9. Turn the ignition switch OFF, remove the inspection adaptor and connect the ignition pulse generator connector.
10. Turn the ignition ON with the registered key.
*The immobiliser system (HISS) returns to the normal mode.
11. Check that the engine can be started using all registered key.
Contact me if you need any more photos, This worked for me but follow this at your own risk!!
Cronin is offline
post #3 of 14 Old 04-19-2009, 2:34 PM
check there via babelfish translator
(Honda H.I.S.S.)
tcannabis is offline
post #4 of 14 Old 07-17-2009, 3:22 AM
Hi,I'm Alessandro from Italy.
I've a question, this procedure is valid although I lost the original key?
But I have another key of another bike equal of mine(hornet 900).
Please help me!!!Thx
jurmy23 is offline
post #5 of 14 Old 07-17-2009, 6:32 PM Thread Starter
Images: 5
Alessandro, if you have lost the only key you had, you will have to replace the ecu and lockset. Have a look on ebay!! Hope this helps. The programming process requires a key that has already been registered with the ecu.
Cronin is offline
post #6 of 14 Old 05-26-2010, 9:35 AM
Hi,
going to make HISS programming cable myself, but don't know what resistor resistance. You wrote that you used 1k resistor, another guy from Add a spare HISS key to your Honda CBR1000RR used 100R one. Do you have any source where the right resistance is mentioned? Maybe it depends on the bike model? Thanks for you answer...
PetrVTR is offline
post #7 of 14 Old 08-07-2010, 4:49 AM
Do you know how to program more keys for the suzuki.
useribot is offline
post #8 of 14 Old 08-07-2010, 5:48 AM
Images: 2
Quoted: 2 Post(s)
Reputation Power: 227
Which Suzuki?
post #9 of 14 Old 08-07-2010, 1:41 PM
Reputation Power: 8
hI Alessandro,
Check out this site www.motomatrix.co.uk .... and contact them ask for Ian, tell them your problem they should be able to help you with a replacement ecu and chip the cost about 250.
clem3 is offline
post #10 of 14 Old 08-08-2010, 4:01 AM
Which Suzuki?
Its the 1000 07 08 moddel and on the tank there is a sticker S A I S on it.
Thank you.
useribot is offline
post #11 of 14 Old 08-08-2010, 5:56 AM
Images: 2
Quoted: 2 Post(s)
Thank you.
I just checked the '05 manual but it doesn't have the key registration procedure.
I don't have the later model manuals sorry.
Have you asked Suzuki what your options are?
What about the Gixxer forums?
post #12 of 14 Old 11-01-2010, 4:11 PM
Reputation Power: 8
Hi guys, where did you get your transponder key blanks from?
I cant find any online that come with the chips in
Monkeh is offline
post #13 of 14 Old 11-02-2010, 7:12 AM
Images: 2
Quoted: 2 Post(s)
A dealer perhaps?
Does Canada have HISS on their bikes?
post #14 of 14 Old 11-02-2010, 7:28 AM
Reputation Power: 8
i found a transponder blank from davesilverspares, cheaper than stealership.
Can someone whos made a tool tell me what size female spade connectors i need in mm please.
thanks monkeh
Monkeh is offline
Human Verification
Search tags for this page
2003 honda cbr 600 ignition used
2006 cbr600rr immobiliser
can i put a new ecu in my bike and program a blank chip cbr 600rr 2007
h.i.s.s transponder cbr 600 rr imobilizer
honda 600rr diagnostic mode
honda cbr 600 hiss
honda cbr 600 immobiliser flashing code 31
honda cbr 600 rr 2009 programming
honda cbr600fs1 new key new ecu programming
immobilizer cbr 600 rr ebay
Hiss Key Programming CBR600rr 03 Cronin Introductions 2 04-13-2009 12:15 PM
Hindle pipe programming question wingerdor Honda FireBlade 5 01-15-2008 1:58 PM
Need programming assistance? evl_twn Off-Topic 4 09-29-2006 10:05 PM
SPEEDTV Programming Changes Red Rider Off-Topic 5 06-24-2003 4:52 PM
SPEEDTV Programming Changes Red Rider Honda FireBlade 3 06-24-2003 4:21 PM
