90 cbr600 No Spark
Old 06-08-2009, 10:12 AM
Bike(s): 1990 Honda cbr600
Rep: Andyman1971 is on a distinguished road (10)
90 cbr600 No Spark
Recently purchased this bike, ran fine till it stopped while riding. Towed it to the house. I have no spark. Checked the Ign switch/good. Checked the run switch/good. Checked resistance of pulse generator/4.3. Manual told me spec was 3.5 - 5.3. So I replaced the control unit. Same problem. Is there another way to test the pulse generator? Am I missing something? All electrical connectors and plugs check out ok.
Thanks,
Andy
Andyman1971 is offline
View Andyman1971's Profile View Andyman1971's Gallery Find More Posts by Andyman1971
Old 07-08-2009, 12:44 PM
Bike(s): 1993 fireblade rr-p
Rep: Milzy has a spectacular aura aboutMilzy has a spectacular aura about (184)
Re: 90 cbr600 No Spark
i had a similar problem on my blade....
it was a broken wire...(mine was only firing on two)
you basically have a triangle of wires
CDI->Ignition Coil
CDI-> Pulse generator Coil
Pulse Generator coil-> Ignition coil
i had a break in one of those . . . found the fault doing a continuity test on the wiring, and fixed it by replacing the wire! the connections were fine, so i just cut the wire and replaced it using the connections at both ends.
2 weeks later same thing happened on the other two cylinders (they all work in pairs, hence only 2 Coils)
never skipped a beat since!
before i found the fault i replaced the CDI, pulse generator coil and the coils & HT leads! all of that expense, and the root cause of the problem cost about 0.01p! (i aquired the wire needed from work!!!)
hope this helps
Milzy is offline
View Milzy's Profile View Milzy's Gallery Visit Milzy's homepage! Find More Posts by Milzy
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 10:12 AM.
