94 CBR 600 F2 Vacuum Diagram??? - Honda Motorcycles - FireBlades.org
post #1 of 2 Old 07-13-2009, 8:39 PM Thread Starter
Can anyone direct me to a site where I can get the diagram for the vacuum lines on my bike? I would really appreciate it, I found one diagram, but it is for the carb assembly.
317coal78 is offline
post #2 of 2 Old 07-14-2009, 9:46 AM
Reputation Power: 8
Send a message via MSN to Cbrfrenzie
Re: 94 CBR 600 F2 Vacuum Diagram???
This may help you out a little bit: F2 - CARBURETOR ASSY. - 1992 Honda CBR600F2
Are you still running the F2 carb's WITHOUT the F3 RAM AIR setup?? If you are running the F2 carbs without the ram air there are less lines to hook up, as the float bowls do not need to see the same pressure as seen in the air box.
Line from #4 cylinder sync port to petcock vacuum port, plus the other 3 sync port holes. There are 2 overflow lines that connect top the 3 way valve, just behind the carb's (hose #36 & 39), and one line that runs into that little black plastic box (not even sure what that thing is) Then there is a large hose that connects the right side of the air box to the cylinder head PAIR valves.
Heres some pics I found of a California model bike from: F2 Vacuum diagram??? [Archive] - CBR Forum - Enthusiast forums for Honda CBR Owners:
http://i224.photobucket.com/albums/d...s/100_1204.jpg
http://i224.photobucket.com/albums/d...s/100_1212.jpg
Here's the California model diagram from the air box lid: http://i224.photobucket.com/albums/d...s/100_1221.jpg
http://i224.photobucket.com/albums/d...s/100_1216.jpg
Hope that helps!
Cbrfrenzie is offline
Human Verification
Need help with 954 vacuum lines Fong Honda FireBlade 9 08-27-2006 7:54 PM
Toolbox vacuum ND4SPD Tools / Garage / Paddock 5 08-08-2005 8:16 PM
Vacuum line to nowhere? NowYaKnow Honda FireBlade 10 06-10-2005 12:09 AM
Dyson vacuum CBR929RE Off-Topic 35 02-08-2005 10:08 PM
The man's vacuum ND4SPD Off-Topic 4 01-30-2004 7:16 PM
