2001 cbr F4i no fuel priming
Old 08-16-2009, 6:23 PM
Bike(s): Honda Cbr f4i 2001
Rep: asantos is on a distinguished road (10)
left the key on so the battery died went and bought a new battery installed it and now the bike wont start the hmm noise i hear once i hit the on switch itsz not happening i guess that the fuel pump priming i checked all the fuses and everythings fine this s**t is gettin me mad im missing the 500 mile ride all becasue of this so please help me
WHEN I TURN THE KEY EVERYTHING GOES ON EXCEPT FOR THE FUEL PRIMING LIGHTS HORN START BUTTON IT CRANKS BUT WONT START
asantos is offline
View asantos's Profile View asantos's Gallery Find More Posts by asantos
Old 08-16-2009, 6:28 PM
cbr1kfireblade's Avatar
Bike(s): CBR1000rr6
Re: 2001 cbr F4i no fuel priming
what happens just when you turn the key on? lights sounds etc?
cbr1kfireblade is online now
Old 08-16-2009, 7:22 PM
Bike(s): 2002 Honda Cbr F4I
Rep: CadilacWill is on a distinguished road (10)
I have the same problem, if anyone knows I would really appreciate some help
it turns over, but just won't catch the fuel pump is good, the spark plugs are good, the ignition is good, and the ecm must be relatively good because it does do everything but start.
From what I have deduced there is no spark, and the pump does not prime I really am at a loss here so any help would be apreciated
CadilacWill is offline
View CadilacWill's Profile View CadilacWill's Gallery Find More Posts by CadilacWill
Old 08-17-2009, 1:57 PM
cadilac did you find out what was wrong
asantos is offline
Old 08-17-2009, 7:36 PM
My latest assumption is the Fuel Cut Off Relay, but I have yet to test it
I'll let you know my results
Old 08-17-2009, 10:16 PM
I jumped the black/white wire to the solid brown wire which made the pump prime and everything
so now I have to find out why I am not getting spark and then my baby will run
If anyone can help me find out why I am not gettin spark I would really appreciate it
Old 08-17-2009, 10:24 PM
hol on where is all this so i can do it
asantos is offline
Old 08-17-2009, 11:43 PM
a starter relay just cost 30 bucksz imma just buy one and see what happensz
asantos is offline
Old 08-18-2009, 12:32 AM
It is not a starter relay it is a fuel cut off relay which is on the way back on the right side. It is under the farthest back fairing
Old 08-18-2009, 1:05 AM
alright i see two relays wich one is it should i buy a new one??
asantos is offline
Old 08-18-2009, 1:13 AM
Here is the process I tried
1. So, locate the Fuel Cut off Relay. It should be on the right side of the rear frame above the rear passenger foot peg.
2. The relay you need is the one furthest back.
3. Disconnect the plug from the bottom of the relay.
4. Insert a jumper wire from the Brown Wire to the Black/White Wire.
5. With the jumper in place, turn the key to the "ON" position for 10 seconds.
6. After 10 Seconds, turn the key "OFF"
7. Remove the jumper wire and re-connect the plug into the relay.
8. Make sure the bank angle sensor is vertical and upright.
9. Turn the key to the "ON" position and flip the Run/Stop Switch to the Run position. You should now hear the fuel pump prime and the bike will now start.
My bike did not start because it did not give me spark, but made my fuel pump prime
I would give it a go
Old 08-18-2009, 3:13 AM
but there is two sets oof brown nd black nd white cables
asantos is offline
Old 08-18-2009, 8:53 PM
YO CADILAC WHATS YOUR EMAIL OR NUMBER SO I CAN GIVE YU A CALL WHILE IM DOING THIS CUZ I CANT GET IT 2 WORK MAN IS THERE SUMTHING I MIGHT B DOING WITCH ONE OF THE 2 BLACK WIRES
asantos is offline
Old 08-18-2009, 10:05 PM
Bike(s): 98F3
Rep: Billygoat is on a distinguished road (10)
Hey Guys
had simular things happen to my bike.
Except mine let some fuel by even if the pump was not working.
If you can't jump the pump with 12V, take the electrical side of the pump off and clean the contact points with a file. Be careful!! not to damage the it while filing/sanding
I did this to my pump cuz the contacts got dirty from arcing. I also used a bigger fuel cut relay, cuz honda wanted 70 for it. I think the pump contacts arced, drawing more juice to the relay.
Anyway, you can check to see if the relay is working by using the three wires.
At fuel cut off relay there is a plug.
Don't know which order they are, but 1 is return to pump. 2. 12V trigger(low amp) 3. 12V (high amp) which powers the pump.
Hope this helps.
Goat
Billygoat is offline
View Billygoat's Profile View Billygoat's Gallery Find More Posts by Billygoat
Old 08-19-2009, 12:57 AM
  #15
the two wires closests to the front on the farthest back relay
that is what worked for me
Old 08-20-2009, 10:19 PM
  #16
Bike(s): 01 CBR 600 F4i
Rep: R Dub is on a distinguished road (10)
Hey guys. Sounds like you were having the same problem that I was having. It turned out to be the headlight harness. The green wire (ground) had a bad connection. Follow your head light harness to the left of the bike where it plugs into the main harness(its a gray connector) and make sure that green wire is not corroded out and is tight. I hear that's a very common issue on these bikes. It you need pics let me know and I will be happy to send you a link.
R Dub is offline
View R Dub's Profile View R Dub's Gallery Find More Posts by R Dub
Old 08-20-2009, 10:28 PM
  #17
yea send me those picsz i wanna do that rite now
asantos is offline
Old 08-20-2009, 10:52 PM
  #18
but wen i hit the kill switch i hear a click
asantos is offline
Old 08-20-2009, 11:18 PM
  #19
Check out this post. Its what helped me out
F4i starting problems - CBR Forum - Enthusiast forums for Honda CBR Owners
Let me know if it works or not
R Dub is offline
Old 08-20-2009, 11:48 PM
  #20
nothing im missing out bike night were i live all my friends are out cuz of this fukin **** iono wtf the battery just died and i try 2 jump my old battery with my car battery Car was off nd i bought a new battery i put it in thinkin everythings gonna b fine now this **** wont start PS wen i jump the fuel cut off relay i hear the fuel pump prime
this s*** is pissin me off all i wanna do is kick it over
asantos is offline
Old 08-21-2009, 12:36 AM
  #21
you said when you jump the fuel cut relay you hear it prime....will it start then?
R Dub is offline
Old 08-21-2009, 12:58 AM
  #22
nope i jump it with a wire nd turnthe key to on with the kill switch to the run position the fuel pump just stays priming so i kno the switch is good nd so is the pump just dnt kno wtf it is i ordered a fuel cut off relay so lets see
yoo yu gotta aim or suttin
asantos is offline
Old 08-21-2009, 10:30 AM
  #23
Yeah man I got AIM. My screename is Rwdirtbike.
But you said when you flip the kill switch you can hear a click which I would imagine would be the fuel cut relay and that means that it is good. I am not trying to rule that out as the problem but I have seen a lot of people think that was wrong, spend the money on a new one and then that doesn't fix it.
You said the bike ran fine before the battery went dead right? I know you probably tried this 100 times but put the battery on a charger and let it sit there for a while. These bikes need a full battery to run. One time my bike would turn over fine and seemed like it should start but wouldn't. Put the charger on it and it fired right up.
Another thing to double or triple check is the kick stand switch. Make sure the bike is in neutral. We have all forgot that once or twice. You might want to bypass that switch to see what happens.
When you turn the key on what lights come on on your cluster?
R Dub is offline
Old 08-21-2009, 1:42 PM
  #24
im just gonna take a video nd post it 2 show yu wat happensz
asantos is offline
Old 08-21-2009, 8:42 PM
  #25
UPDATE: got a new fuel cut off relay bike still doesnt start when i use a jumper wire the pump will prime wen i put the relay nothing at all i feel like burning this f***** bike
asantos is offline
Old 08-21-2009, 9:24 PM
  #26
Sorry man that sucks. I thought it might not fix it though. The relays are not known for going out. Snap a pic of your cluster when the key is on and post it.
R Dub is offline
Old 08-25-2009, 1:41 AM
  #27
UPDATE BIKE IS FIXED THANKSZ EVERYONE MY BIKE WAS PREVIOUSLY REWIRED BY A STEALERSHIPND LIKE ALWAYSZ IT WAS HALFASSED SO WEN I REMOVE THE ECU TO CHANGE THE BATTERY A CABLE FOIR THE ECU THAT WAS ONLY CONNECTED BY TAPE FELL OF I NEVER NOTICED TILL MY 7 YEAR OLD BROTHER CAME IN TO THE GARAGE ND SAID WATSZS THAT CABLE DOING OUT SO IT WAS DUMB OF ME NOT TO SEE THAT SO NOW IM HAPPY GOT MY BIKE BACK ND MY BROTHER IS HAPPY HE GOT MCDONALDSZ AND A POCKET BIKE
asantos is offline
Old 08-26-2009, 9:51 PM
  #28
Rep: gumby456m is on a distinguished road (10)
i'm having this problem on my 2002 F4i also. checked all the fuses, and headlights work. I am getting spark, and tested both the engine cutoff relay and the fuel cut off relay relays and they both click when i gave them voltage. the fuel pump does not prime, but I connected the pump directly to the battery and it worked. When i turn the kill switch on I dont hear any click from the relay. I also bypassed the tip-over sensor and that didn't help so i'm assuming thats fine too. so then I followed these steps CadilacWill posted
When I put the shorted wire on, the fuel pump started going so I started the bike and it ran fine. Unfortunately after i put the relay back I was back to square one with it not starting again
thanks for any help
gumby456m is offline
View gumby456m's Profile View gumby456m's Gallery Find More Posts by gumby456m
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 10:11 PM.
