Bike Dies At 230 degrees??
Old 10-27-2009, 12:23 AM
Bike(s): '01 cbr600 F4i
Rep: BasetotheFACE is on a distinguished road (10)
Send a message via Yahoo to BasetotheFACE
The engine cuts off when bike is idle at about 220 and 230 degrees mainly when im on the streets at a red light never while on the move i actually got back to the house let in idle in the driveway and it would cut off about 2-4 mins into letting it sit, ive checked coolant levels everything is fine actually toped off coolant level wait about and hour or two then went back on the rode and the bike did it again at a red light (was actually next to a hottie in a new black audi and i looked like a dumbassfor staling the bike)
just start happening today idk if bike overheated and died or wat but it stays on when i keep the RPM's up but dies in an idle RPM's start dippin below 1RPM then just cuts.....
fan is running, also might lights dim when i ride at low idle (could it be battery issue??)
all hose are intact and no cracks even went as far to check all fluids including oil, radiator, break, and coolant...
in advance thanks for the help
Last edited by BasetotheFACE : 10-27-2009 at 7:36 PM. Reason: better discription...
BasetotheFACE is offline
View BasetotheFACE's Profile View BasetotheFACE's Gallery Visit BasetotheFACE's homepage! Find More Posts by BasetotheFACE
Old 10-30-2009, 3:09 AM
Bike(s): 01 RC51 :)
Rep: RiotSauce is on a distinguished road (12)
Send a message via AIM to RiotSauce
Re: Bike Dies At 230 degrees??
2-4 min after its fully warmed up? Or from the second you turn on the bike?
RiotSauce is offline
View RiotSauce's Profile View RiotSauce's Gallery Find More Posts by RiotSauce My Map Location
Old 10-30-2009, 4:02 AM
i actually already figured it out it was actually a throttle issue my throttle was running on the low end and when the bike would get hot it would try to drop the RPM's to cool off a little so i set higher throttle idle and so far no issues what so ever.... actually runs better brought idle up to bout 1.5 1.2 RPM's the original owner had it sitting at 1RPM a little under so i just adjusted it and its working just fine now
but thanks
Old 10-30-2009, 5:22 AM
Out Of Many, We Are One
Twincam's Avatar
The idle should be about 1200-1400RPM (give or take a bit)
Twincam is offline
Old 10-31-2009, 9:37 PM
ya i set it right bout there......
Old 11-11-2009, 1:37 AM
Bike(s): CBR 400
Rep: On The Road is on a distinguished road (30)
I was having the same issue with my CBR 400 until I turned up the throttle adjust a touch.
On The Road is offline
View On The Road's Profile View On The Road's Gallery Visit On The Road's homepage! Find More Posts by On The Road
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 7:32 AM.
