fuel leak - Honda Motorcycles - FireBlades.org
post #1 of 16 Old 05-11-2010, 10:30 PM Thread Starter
fuel leak
hello. first time posting. bought a 93 cbr 600 f2 in october. stored
the bike and ran it periodically throughout the winter. just recently after it had sat, there was a fuel leak which me and my mechanic friend diagnosed as bad o-rings on the t valve between the carbs. after that there were no leaks and bike ran fine. just yesterday we got back from a ride and fuel started leaking severly. turned the bike off and let it sit and turned it back on to see the leak but there was no leak to be seen and the bike was
running fine.
now when we noticed it was leaking i had just pulled into the garage at idle but the driveway is sloped about 20-25 degrees downward from the street. and when i say leaking severly it was as if you dumped 1/4 of a gallon of gas on the ground.
also note i replaced the float needles an inspected the carbs which were
very clean.
so my question is if any of you have heard of
this before? and suggested fixes? thanks for any help.
tranoca is offline
post #2 of 16 Old 05-11-2010, 11:25 PM
Images: 2
Quoted: 2 Post(s)
Reputation Power: 227
Re: fuel leak
running fine.
very clean.
Full tank of fuel?
Could be the overflow or the breather may be blocked.
You really need to determine where it's coming out off to be able to find the source.
post #3 of 16 Old 05-12-2010, 1:51 AM Thread Starter
Re: fuel leak
3/4 to 1/2 full. i guess thats the problem though.. it was a one time thing and didnt leak after we restarted the bike. ill check out the floats and needles tomorrow. i was just hoping someone else had a similar issue. thanks.
tranoca is offline
post #4 of 16 Old 06-11-2010, 7:51 AM
Re: fuel leak
I have the exact same problem with my 1994 CBR900RR. AND I have tried the same solution by replacing the o-rings about 5 years ago. It seemed to have worked- for a while.
When most people hear the word "leak", they think a drop or 2. Not in this situation. Gas literally pours out of the bike. I could understand the leak better if it didn't stop.
Here's the routine- Every time I start my bike gas comes pouring out. I'll let it run for about 30 seconds and then shut it off. I repeat the process until gas no longer leaks out. Once it stops leaking it never leaks again until it it is shut down for a long period of time.
I admit that I have NO clue. My assumption still lead back to the o-rings. I figured that as they heated up and expanded they blocked the leakage.
Now I read that your bike was leaking AFTER a ride and that concerns me greatly even though I have yet to experience it. I do think it's cute that you referred to it as a "one time thing". I thought so too and I'm still scratching my head trying to nail down the cause.
djmerchant is offline
post #5 of 16 Old 06-11-2010, 11:48 AM Thread Starter
Re: fuel leak
turned out the hose was cracked under the hose shroud so we couldnt see it at first. the o rings definitely needed to be replaced but it wasnt responsible for the huge gas dump. it was funny because it would only leak when the hose was flexing a certain way.
i dont know your situation but the o rings shouldnt have to heat up to stop a
leak. they either leak or they dont. but good luck.
tranoca is offline
post #6 of 16 Old 06-11-2010, 12:10 PM
Images: 2
Quoted: 2 Post(s)
Re: fuel leak
Where from exactly?
post #7 of 16 Old 06-11-2010, 5:24 PM
Images: 3
Reputation Power: 9
Re: fuel leak
Ethanol in the fuel is eating the rubber fuel lines guys, check All the fuel lines....plus rubber degrades over time...dry rot even in the wet....Uv rays from the sun and all..plus extensive heat from your engine will dry out a rubber line............
Our House is Protected By the Good Lord and a Gun, and You might Meet them both If you show up here Unwelcome son.
blacksheep is offline
post #8 of 16 Old 06-12-2010, 5:43 AM
Images: 2
Quoted: 2 Post(s)
Re: fuel leak
That's why I'm guessing the diaphram in the fuel tap might be shot.
But it depends entirely on exactly where the fuel is leaking from.
post #9 of 16 Old 06-12-2010, 12:26 PM
Images: 3
Reputation Power: 9
Re: fuel leak
hate to say it, but when the peep's online here ask for help, they get Very, very vage about the actual problem, leaving us to wrack our brains to figure out a solution...
post #10 of 16 Old 06-12-2010, 3:45 PM
Images: 2
Quoted: 2 Post(s)
Re: fuel leak
It can be annoying but I think that's just how it is.
If somebody has a clearer understanding of how to describe their problems there's a chance they're also able to diagnose and fix it themselves :-)
It can be helpful though to give us some idea of how confident they might be in fixing it themselves, which sometimes means the best advice we can give is to take it to somebody to fix.
The really difficult ones are when the problem is described with slang or incorrect terms - those can be challenging :-)
post #11 of 16 Old 06-12-2010, 5:16 PM
Images: 3
Reputation Power: 9
Re: fuel leak
well put Blade, i guess i was getting a lil iritated trying to answer and help, but i understand now...not all motorcyclists have the ability to work on their own machines....remembering back to my first F2, that poor thing sat apart during the winter more than it was together, i have small containers like 3x3 in size with nuts, bolts and body clips that were never mounted back on the bike after my many exploritory tear downs....and nothing ever fell off...luckly me i guess....oh and nothing was ever really wrong with my bike. i was just a very curious kid growing up...i would tear stuff apart just to see what made it 'tick"...
post #12 of 16 Old 06-14-2010, 10:05 PM
Re: fuel leak
LMAO @ blacksheep. When I take things apart they never tend to go back together the way they were intended. Trust me when I tell you that I am not embarrassed by mechanical ineptitude. Sure I wish I had a clue, but it is what it is and I accept it.
Blade- I mainly asked the question here because Google led me to this forum because someone had a similar problem. Sure- I WAS hoping to find an "Ahah!!" moment and a quick fix. But when is anything ever THAT easy?
Believe me guys, I appreciate any help that you are willing to give me in fixing this problem.
I am assuming (once again) that the best way to track down the exact point of the leak is to remove and elevate my gas tank so that I can get a clear view of what is happening underneath to pinpoint the leak. I have had my gas tank off a couple of times which is the easy part. Do you have any suggestions how an idiot like me can safely elevate my gas tank so that it can feed fuel and have minimal risk of it coming crashing down? Or is there a better way to troubleshoot the leak? (If anyones says "with a match" so help me!!! lol)
post #13 of 16 Old 06-14-2010, 10:27 PM
Images: 2
Quoted: 2 Post(s)
Re: fuel leak
I prefer to just tie up a meter of fuel line and fill that with fuel. It's enough to run the engine for a couple of minutes but you're looking for a leak that happens when the engine isn't running?
post #14 of 16 Old 06-14-2010, 10:38 PM
Re: fuel leak
It leaks only when it IS running, Bro. I will remove the gas tank altogether. "just tie up a meter of fuel line and fill that with fuel"- please explain the technique???
post #15 of 16 Old 06-14-2010, 10:49 PM
Images: 2
Quoted: 2 Post(s)
Re: fuel leak
Remove the tank or prop it out of the way.
Disconnect the fuel line and reconnect a meter length of fuel line.
Tie or tape the end up to your ceiling or a broomstick or whatever else you have.
Fill the line with fuel.
You now have a very small fuel tank :-)
Be sure to plug the vacuum line if it has a vacuum-controlled fuel tap.
Human Verification
Search tags for this page
1995 cbr 600 f3 breather tube leak during refuel
1998 honda cbr600fw overflow leaking fuel
89 cbr 600 f is leakin gas from gastank
95 honda cbr 600 f3 fuel leak from intake
after storage gas leaked out frpm carb1996 cbr 600?
cbr 600 f fuel tank breather blocked
cbr 600 f2 leaking fuel
honda 600 motorcycle leaking gas
honda motorcycle fuel overflow hose location
leaking cbr1100 fuel tap breather
Fuel Leak Out of Cap AEngineer85 Honda CBR 600 4 04-26-2010 1:27 PM
Fuel Leak: Need Help.. mightyolds Honda Cruisers 3 04-01-2010 2:48 PM
Fuel leak? Oops2low Honda FireBlade 23 01-30-2010 3:58 PM
Gas / Fuel tap leak? chakraist Honda FireBlade 17 11-04-2009 7:34 AM
954 Fuel Leak Problem......Help tdeal28 Honda FireBlade 8 03-18-2006 4:18 PM
