Bike Wont Start. Makes Clicking Sound - Honda Motorcycles - FireBlades.org
post #1 of 18 Old 01-27-2011, 3:02 PM Thread Starter
So i just bought this bike last week from this guy and it worked fine. Then a few days ago after riding for about 10 mins i turned it off and then tried to start it back up a minute latter and it wouldnt start. It light up, headlights came on, and Fuel Injector primed but when I hit the ignition all i heard is a click sound. I tired again a few minutes later and it started up.
Since then though the problem has gotten worse. After starting the bike i would have to wait a few hours before i can start it up again. Again the bike lights up and the fuel injector primes but all i hear is click. More so, this morning the bike wouldnt start at all even though i havent ridden it for 2 days.
I have already tried just jumping the bike and then i got the battery checked and charged but to no avail.
Any suggestions would be appreciated. Thanks
gehado is offline
post #2 of 18 Old 01-27-2011, 3:15 PM
Reputation Power: 7
Re: Bike Wont Start. Makes Clicking Sound
sounds like the starter to me
tony_929 is offline
post #3 of 18 Old 01-27-2011, 3:53 PM Thread Starter
Thanks for the speedy response.
How exactly do I get to the starter and is there a way to check it for functionality before replacing it?
gehado is offline
post #4 of 18 Old 01-27-2011, 3:57 PM
yeah i would say the starter/starter solenoid sticking as u have a fully charged battery
tom140 is offline
post #5 of 18 Old 01-27-2011, 4:04 PM Thread Starter
Somebody was telling me that i should change out the R/R. Could that have anything to do with it?
gehado is offline
post #6 of 18 Old 01-27-2011, 4:43 PM
Reputation Power: 8
Check your wiring, it could just be a loose connection or a worn cable.
I had it happen on my ninja a few weeks ago.
Monkeh is offline
post #7 of 18 Old 01-27-2011, 4:46 PM Thread Starter
I appreciate the advise will do but are we talking the wiring to the battery or to something like the stater, etc. Thanks
gehado is offline
post #8 of 18 Old 01-27-2011, 8:18 PM
Reputation Power: 8
It was the starter relay connector on my ninja that was loose.
Put the battery on a trickle charger overnight something like 2A for a good 10 hours
Check the battery with a multimeter and make 100% sure its good.
Im no expert but i believe the clicking is coming from the starter relay and its doing so because the voltage at the starter relay is dropping below it's needed voltage. The reason the voltage drops is due to insufficient current to the starter motor, which could be:
1) Insufficient battery charge
2) Mechanically-bound starter motor
3) loose or corroded connections in the starter circuit
look at the troubleshooting guide here:
http://www.venselenterprises.com/tec...ingarticle.pdf
I believe the starter relay is under the seat next to the battery near the junction box.
The starter motor on the other hand is alot harder to get to.
Download the manual if you haven't done so already.
hondatech.info: Honda service manuals
Monkeh is offline
post #9 of 18 Old 04-12-2011, 6:52 PM
Hey, Im having the same issue with my 04' 1000rr...
Bought new battery, worked fine for a few days then died.
Fully charged battery, and it worked for a day then died.
Always starts from a car jump.
Just clicks when it taps out.
I took it to the Iron Pony service shop here in Columbus, they checked the charging system and said it was fine and faulted the battery. didnt even charge me the $87 service check fee as I bought the battery from them days before.
But problem still there.
The bike seems to work fine if I travel longer distances or not too many stops. But if I travel in high traffic or make more then 2 stops, i'm suspect to be stranded somewhere. Even started riding with jumper cables just in case.
I recently upgraded to a better quality battery and did some diagnostics on the R/R but it seems fine. I'm wondering if my relay could be the problem. I have an undertail exhaust and it gets extremely hot down there. Could the extra heat cause the relay not to perform?
gehado.. did you find the problem?
cclay is offline
post #10 of 18 Old 04-12-2011, 6:55 PM
Reputation Power: 7
loose connection on the battery, my bike AND truck have done the same thing, just check the connections again
vtchopperdude is offline
post #11 of 18 Old 04-13-2011, 10:33 AM
Reputation Power: 8
Try going out for a long ride and get the bike nice and hot, then test the charging system. My guess is the r/r is failing when it gets hot.
Just had this happen to my cbr6.
Monkeh is offline
post #12 of 18 Old 04-15-2011, 1:29 PM
So the new battery has been working well so far, but havent pushed the limits.
Be back with results
cclay is offline
post #13 of 18 Old 06-15-2011, 4:07 PM
cclay or gehado, have your starting problems been resolved? I'm having a similar issue. I'm just wondering what you guys did to finally fix the problem. What is the battery?
OUPEbiker is offline
post #14 of 18 Old 07-22-2011, 10:25 PM
its your regulater dude mine did the same thing
Customf4i is offline
post #15 of 18 Old 07-22-2011, 10:29 PM
that or the stator, that keeps the battery charger when riding it
Human Verification
Search tags for this page
2008 suzuki 450 axi wont start clicking coming from under the seat
bike clicks when won't start
cbr600rr wont start just clicks
honda shadow making clicking noise and not starting
just get a click when starting motorcycle
motorcycle keeps clicking when i try to start it
motorcycle wont crank only click
motorcycle wont start just clicks
my 84 honda vf700f interceptor bike just clicks when i try to start it
when i push the start button on my motorcycle it won't start i hear a click in the junction box
bike wont start stokedssp08 General Discussion 3 10-30-2009 5:49 PM
MY bike wont start. Hondarider4life Electronics 3 08-17-2008 1:41 AM
bike wont start 03degrassi Honda CBR 600 1 08-01-2008 10:03 AM
CBR954RR clicking sound? BadBrad Honda FireBlade 12 08-13-2007 12:12 PM
i know i know my bike wont start greyhound_dude7 Honda CBR 600 8 04-03-2007 1:44 PM
