02-08-2004, 11:37 AM
Bike(s): 02 RSVR, 01 GSXR Age: 36 Posts: 3,595
Rep:   (144) Rep Power: 10
| gearing i took off the rear when for a change and have 2 extra gears lying around and was wondering what I am buying by switching from the 48 I have now to a 45 or a 42. |
02-08-2004, 11:43 AM
| Re: gearing One VERY tall first gear and poopier acceleration . . . |
02-08-2004, 1:50 PM
| Re: gearing 45 is OEM, isn't it? |
02-08-2004, 1:51 PM
| Re: gearing Make sure keep an eye on chain length too if you're changing that much! |
02-08-2004, 5:10 PM
| Re: gearing Quote: |
Originally Posted by abtech One VERY tall first gear and poopier acceleration . . . |
i already have poopy acceleration, i dont need anymore.
should i go up to a 50 or so then? |
02-08-2004, 6:24 PM
Originally Posted by bubba i already have poopy acceleration, i dont need anymore.
should i go up to a 50 or so then? | Can't you drop a tooth on the countershaft sprocket? This would make the most difference without having to add any links. |
02-08-2004, 7:11 PM
Originally Posted by abtech Can't you drop a tooth on the countershaft sprocket? This would make the most difference without having to add any links. |
i could, but i already had these gears lying around. how many would you drop  , i am at 15 now.
i am looking to have more responsiveness down low since i cant seem to keep it high ( i think it is the sound, i hear the high revs and shift instictively) especially since buying the twin |
02-08-2004, 7:22 PM
Originally Posted by bubba i could, but i already had these gears lying around. how many would you drop  , i am at 15 now.
i am looking to have more responsiveness down low since i cant seem to keep it high ( i think it is the sound, i hear the high revs and shift instictively) especially since buying the twin | I would drop one tooth and keep the 48. Give this a try before you go any further, you are at 3.20 to 1 with 15/48, so 14/48 will bring you to 3.43 to 1. This is getting pretty low already, but that's misleading depending on where you are going to run the bike. Road Atlanta's back straight would seem to require something quite a bit higher (like 15/43 or so), but then I'm not certain where you are running these days . . . |
02-08-2004, 10:07 PM
Originally Posted by abtech I would drop one tooth and keep the 48. Give this a try before you go any further, you are at 3.20 to 1 with 15/48, so 14/48 will bring you to 3.43 to 1. This is getting pretty low already, but that's misleading depending on where you are going to run the bike. Road Atlanta's back straight would seem to require something quite a bit higher (like 15/43 or so), but then I'm not certain where you are running these days . . . |
i think road atlanta will be the exception to my track riding - as i can only seem to get on there 2 times per year with nesba. Probably more like Jennings, CMP, maybe VIR |
02-08-2004, 10:10 PM
oh yeah - THANKS  |
02-08-2004, 11:04 PM
Bike(s): '02 Posts: 559
Rep:  (10) Rep Power: 7
| Re: gearing You probably already know this but 15/43 is what came stock. |
02-09-2004, 8:09 AM
| Re: gearing actually I had no idea. i bought the bike track prepped and never owned an F3 before. |
02-12-2004, 9:59 AM
#13 |
Originally Posted by Northy You probably already know this but 15/43 is what came stock. |
actually for future reference the stock setup was 15/44 |
02-12-2004, 10:14 AM
#14 |
Bike(s): 2003 BabyRR Age: 30 Posts: 3,986
| Re: gearing hmmm, things change over the years... the 600RR has 16/43 stock, just like the 929RR. |
02-12-2004, 10:20 PM
#15 |
Originally Posted by bubba actually for future reference the stock setup was 15/44 | You sure it wan't 15/43?  |
02-12-2004, 10:28 PM
#16 |
Bike(s): 01 929 Age: 33 Posts: 121
Rep:  (10) Rep Power: 5
| Re: gearing the F2 is definitely 15/43, and I thought the F3 was the same...  |
02-13-2004, 12:25 AM
#17 | | Mr. Brownstone
| Re: gearing The F3 stock is 15/43. The F3 responds very well with a 14 countershaft sprocket. I kept 43,45,46 and 48 tooth rears in my van. To be honest, I found the 14/46 combination very much to my liking at most tracks, and a good place to start when finding the optimal gearing. |
02-13-2004, 8:21 AM
#18 |
Originally Posted by Northy You sure it wan't 15/43?  |
yeah - i pulled up a site that listed all the stock features of every bike and when i chose the 97 F3 the gearing was 15/44 |
02-13-2004, 10:22 AM
#19 | | Mr. Brownstone
| Re: gearing That is interesting. I know my '96 F3 was 15/43. I guess they changed it up for the '97-'98s.  |
02-13-2004, 10:06 PM
#20 |
Originally Posted by BDA116 That is interesting. I know my '96 F3 was 15/43. I guess they changed it up for the '97-'98s.  | Yeah, I had a '95 and it was 15/43. I even checked the fiche on Ron Ayers and it listed a 43 on the '97-'98 models. |
02-19-2004, 8:09 PM
#21 | | Everything you do can get you killed
Bike(s): 2003 954RR Age: 30 Posts: 946
i dont know bout that one ................my 98 is 15/43
and my best friends 96 is 15/43 |
02-22-2004, 6:49 PM
#22 |
Bike(s): none again...so far... Age: 31 Posts: 4,011
Rep:  (87) Rep Power: 12
| Re: gearing i had a 15/46 on my F3. It helped quite a bit down low for the 2nd gear wheelie. top speed dropped to about 135 from 145. (or so the speedo said...but I never went that fast...  ...much)
(back in the day squid talk, please understand...things have changed... a little)
