Fried something by reversing polarity of battery on f2 - Honda Motorcycles - FireBlades.org
post #1 of 5 Old 08-07-2011, 6:43 PM Thread Starter
Hey guys,
So I feel really stupid and I'm blaming it on my brain still being holiday. Anyways, I hooked up the battery backwards and obviously nothing worked. I switched it to the correct posts but now I'm still getting no signs of power. The 30a fuse below the seat is good and so are the other fuses. The ignition switch reads infinite and zero resistance across it for off and on so that's not why I'm seeing no lights when I turn to on.. Starter doesn't go either. Between ground and the black/white at the killswitch I read battery voltage while at the ECM, I get zero volts between black/White and ground whether the ignition is on or off? Any ideas as to what the reversed polarity battery connection might have damaged? Thank you!
Matroy is offline
post #2 of 5 Old 08-07-2011, 11:17 PM Thread Starter
Re: Fried something by reversing polarity of battery on f2
Once again I am grateful and Surprised by honda's dummy proof machine. The 30a fuse I found under the seat and that was perfectly fine was the backup. The other one under the connector boot was fried... Changed that and I'm on the road again! Doh.
Thanks for reading :p
Matroy is offline
post #3 of 5 Old 08-24-2011, 10:26 PM
I just did the same thing duh! Was that the only issue that you had after? I have a 750 shadow, going out to check the 30 now its not under thew seat but off to the right side. Keep your fingers crossed for me I need to ride to Hotlanta this weekend!
Heavenlee is offline
post #4 of 5 Old 08-25-2011, 1:36 AM Thread Starter
Hey. From what I was able to tell, there have been no other issues once I replaced the fried fuse. The only other issue was that when moving the gas tank for troubleshooting, I pinched the breather lines to the tank, resulting in a no start problem. Now that that's all sorted, she runs beautifully again. Hope all goes well for you!
Matroy is offline
post #5 of 5 Old 08-25-2011, 10:01 PM
Well I've replaced the 30 amp which was blown and the spare was corroded so I got a new pack. I key in , lights come on now, but when I push in the starter button it trips. Pull out the fuse...turn key, flip switch push button...trips again! Could use some help here guys! I don't want to miss Hotlanta this weekend!
Human Verification
Search tags for this page
accidentally hooked motorcycle battery reverse
battery 1995 honda polarity switched
cbr f2 hooked battery up backwards
cbr600 f4 jump start reversed
connected battery backwards motorcycle
fried bike batterh
honda cbr fried black
hook up motorcycle battery backwards
hooked up battery backwards cbr f2
i hooked my motorcycle battery up backwards
Reversed Battery Polarity, Need Help Bike Won't Start Now!! 2007BruteForce Honda Naked Sportbikes 11 11-02-2011 2:08 AM
Reversing rotational direction on a rear slick tyre? TheJackal Honda FireBlade 14 06-22-2010 8:30 AM
Honda CL360 1975 Reverse Polarity Issue jonathantaee Honda Cruisers 4 05-23-2008 5:40 PM
Reversing or flipping tires? Zippy General Discussion 25 05-25-2005 10:26 AM
how to determine wire polarity stegen Off-Topic 15 04-02-2004 12:49 AM
