Why Are Synthetic Oils With Moly bad for my bike
Old 02-19-2004, 7:19 PM
SPY
Everything you do can get you killed
SPY's Avatar
Bike(s): 2003 954RR
Rep: SPY is a jewel in the roughSPY is a jewel in the roughSPY is a jewel in the roughSPY is a jewel in the rough (345)
Send a message via AIM to SPY Send a message via MSN to SPY Send a message via Yahoo to SPY
Like the standard honda HP4? I mean why would honda put out an oil that is bad for its bikes?
I am asking cause that is the oil that is in my F3. Honda 20W50 Synthetic W\ moly
SPY is offline
View SPY's Profile View SPY's Gallery Find More Posts by SPY My Map Location
Old 02-19-2004, 7:21 PM
ND4SPD's Avatar
Bike(s): '84 Magna V30
Re: Why Are Synthetic Oils With Moly bad for my bike
Scroll all the way to the bottom of this page and look at "Similar threads"
ND4SPD is offline
Old 02-19-2004, 7:37 PM
SPY
SPY's Avatar
Bike(s): 2003 954RR
Thank you...............
Well I read it and there is no definate answer. just alot of back and forth conversation agreeing and disagreeing. Has it ever been decided that is is bad or not? Oh well I will keep it in for now till the next oil change.
SPY is offline
Old 02-19-2004, 7:44 PM
CBRBob's Avatar
Molybednium Disulfide (moly for short) is a excellent high temp lubricant! It is actually attracted to and works better the higher the temp of the part it is lubricating. Problem is the clutch gets pretty hot, it attracts it, lubes it, slips it, glazes it up, ruins it. Its fine in moderate hp bikes or bikes with dry or separate clutches (Ducs, HDs).
CBRBob is offline
Old 02-19-2004, 7:46 PM
Bike(s): 2000 929
Rep: Zippy will become famous soon enoughZippy will become famous soon enough (105)
To sum it up, the only thing that can possibly be bad is that it may cause clutch slippage. If that is not happening for you, I would not worry about it.
I put an oil with Moly in my 929 when it had just a few thousand miles on it, and the clutch did slip, ever so slightly. I changed it out right away, and the slipping went away. Some other people have not noticed any slipping after going to an oil with Moly. In general, it is best to get a synthetic without moly.
Zippy is offline
View Zippy's Profile View Zippy's Gallery Find More Posts by Zippy
Old 02-24-2004, 8:03 AM
Bike(s): 02 Honda VFR800
Rep: ytry is on a distinguished road (10)
You can use synthetic oil just make sure it does not have molly. Honda HP4 without molly will work fine. The HP4 with molly was designed for the 1200 and 1500 Goldwings. The molly will cause the clutch to SLIP, no question about it.
ytry is offline
View ytry's Profile View ytry's Gallery Find More Posts by ytry
Old 02-24-2004, 8:54 AM
CBRBob's Avatar
I never heard that before. I used HP4 in my F2 back when when it was a true 102rwhp bike on the street. Never had a problem. When I took it to the track....slippage. Tried some Motul semi-synth, no moly, it was fine.
CBRBob is offline
Old 02-24-2004, 9:15 AM
Once again, HP4 w/o molly is fine in all modern (99 up) Honda motorcycles. Our shop does NOT even sell the HP4 with molly any longer.
ytry is offline
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 3:14 PM.
