Water pump issue - Honda Motorcycles - FireBlades.org
Honda CBR400RR Discuss the Honda CBR400RR in this section. This part of fireblades also covers the Honda CBR 250 and CBR 125.
post #1 of 4 Old 04-21-2017, 10:29 AM Thread Starter
Water pump issue
hi guys,
I have a 1991 Honda CBR 400 RR NC29 (L)
i recently got the radiator replaced and after that i noticed the coolant leaking from the water pump weephole.. but it does not leak all the time... is this normal if the water pump goes bad..?
Anojen is offline
post #2 of 4 Old 04-21-2017, 10:38 AM
Quoted: 152 Post(s)
Reputation Power: 23
Re: Water pump issue
Anything mechanical can go bad. If it is leaking out of the weep hole, then the pump is failing. It will only get worse and eventually you'll not have enough coolant to keep the motor cool and run the risk of motor damage.
lanbrown is online now
post #3 of 4 Old 04-21-2017, 11:53 AM
spagiratwink's Avatar
Quoted: 103 Post(s)
Reputation Power: 7
Originally Posted by Anojen View Post
hi guys,
Hi, could be that the seals have gone, this could have been a reaction with the coolant if changing from IAT to OAT coolant, did you change the coolant yourself if so what was the colour coming out and what colour went in, further reading here
Antifreeze types iat, poat, hoat, nmoat. Recycled coolants.
http://www.flowkoolerwaterpumps.com/..._failures.html
spagiratwink is offline
post #4 of 4 Old 04-22-2017, 11:40 PM
Quoted: 128 Post(s)
Reputation Power: 2
Interesting...I never noticed weep hole(s) on my bikes before. I'll go look soon enough. But it explains why some tracks don't allow Glycol based fluids.
-2006 CBR1000RR- Jardine RT-1 CF, GP Shift rearsets, GP Suspensions 20mm revalve, Penske 8987 triple clicker
-2002 CBR600F4i (was mine and now hers)
Ohlins, Racetech, Showa custom Suspension
Jaybird180 is offline
Go Back   Honda Motorcycles - FireBlades.org > Honda Motorcycle Models > Honda CBR400RR
Human Verification
96 CBR 900rr water pump issue Jdavis2316 Honda FireBlade 4 07-24-2015 4:54 PM
Water pump on a 919 truerockmusicia Honda Naked Sportbikes 22 11-20-2012 12:01 PM
Thermostat and water pump mrdave25 Honda RC51 3 10-16-2007 4:43 PM
95 cbr f3 water pump same as 98 cbr 600 water pump? byc_panty Honda CBR 600 1 05-24-2007 3:34 PM
954 Water Pump psustang89 Honda FireBlade 2 03-28-2007 9:50 AM
