Charging issue - Honda Motorcycles - FireBlades.org
Honda CBR400RR Discuss the Honda CBR400RR in this section. This part of fireblades also covers the Honda CBR 250 and CBR 125.
 4Likes
  • 1 Post By lanbrown
  • 1 Post By IanDoohan
  • 1 Post By Anojen
post #1 of 11 Old 06-16-2017, 3:51 PM Thread Starter
Charging issue
hi all,
will a regulator rectifier charge a completely drained battery?
Anojen is offline
post #2 of 11 Old 06-16-2017, 3:56 PM
Quoted: 174 Post(s)
Reputation Power: 23
Re: Charging issue
The charging system as a whole will yes, it will take some time though. You're better off using a battery charger to get the battery at capacity. A 30 minutes ride won't charge the battery, nor will an hour it will be much longer than that.
Anojen likes this.
lanbrown is online now
post #3 of 11 Old 06-16-2017, 4:12 PM Thread Starter
Re: Charging issue
the rectifier in my bike was fried and stopped charging the battery.. i replaced it with an oem part and i jump started the bike using my friends bike because the battery was totally dead.. checked the volts on the battery and it was working correctly as mentioned in the manuals.. then went out for a 30 minute ride without stopping the bike and came home and turned off the bike and tried to restart again and it cranked slowly and then stopped and started to click.. again jump started using my friends bike and checked the charging system was perfect.. maybe 30 minutes ride is not enough to charge a complete dead battery i guess..
Anojen is offline
post #4 of 11 Old 06-16-2017, 4:42 PM
Quoted: 174 Post(s)
Re: Charging issue
30 minutes is nowhere close, it will take hours. Use a battery charger and charge the battery.
COBRA90GT likes this.
post #5 of 11 Old 06-16-2017, 4:56 PM
Heeza Y Zasch
unslow1's Avatar
Quoted: 218 Post(s)
Reputation Power: 41
Re: Charging issue
unslow1 is offline
post #6 of 11 Old 06-16-2017, 8:04 PM
President Team Full Chat
Images: 4
Quoted: 241 Post(s)
Reputation Power: 74
Re: Charging issue
Generally speaking from my experience, a battery that has gone flat from a failed charging component rarely survives that event. So, if you do end up putting a "full charge" on your battery, it still might not be able to deliver the voltage required to start the bike and/or will not be reliable.
unslow1 likes this.
IanDoohan is offline
post #7 of 11 Old 06-16-2017, 10:41 PM
Re: Charging issue
I agree with IanDoohan. Rarely do they survive. I have had a BatteryMinder bring some back to life but it's rare.
Dirty1 is offline
post #8 of 11 Old 06-16-2017, 11:01 PM
Quoted: 174 Post(s)
Re: Charging issue
I was thinking the same thing but if you charge it and it can't you know its bad but if it does and can start the bike, then it is good. Given that it could take a tank of fuel to charge the battery without shutting it off, you're better off charging it rather than having the bike do it unless the OP likes jump starting the bike to find out.
post #9 of 11 Old 06-17-2017, 3:48 PM Thread Starter
Thanks everyone.. I fully charged the battery and installed it on my bike and now it"s running perfect.... And one more question.. "Is it bad to install hid lights on a 400rr?.. Some say it will melt the rectifier & wirings.. I'm currently running hid bulbs and maybe that should've fried the rectifier.
IanDoohan likes this.
Anojen is offline
post #10 of 11 Old 06-17-2017, 4:09 PM
Quoted: 174 Post(s)
Re: Charging issue
Is the wattage the same or less than the stock bulbs? If it is the same or less, then it can't melt the wiring. What you can run into with less wattage though; reduced R/R and stator life.
post #11 of 11 Old 06-17-2017, 4:47 PM Thread Starter
12v 35/55w is standard
But i'm running 100/55w right now
Anojen is offline
Go Back   Honda Motorcycles - FireBlades.org > Honda Motorcycle Models > Honda CBR400RR
Human Verification
Is This A Charging Issue? motomodmach Honda CBR 600 6 02-09-2015 12:48 PM
Charging issue 01honda929rr Honda FireBlade 15 10-22-2014 9:07 PM
98 RRW Charging Issue? Bubbamcf Honda FireBlade 8 03-05-2014 1:22 PM
Charging issue KINDA tacmo0229 Honda FireBlade 3 04-12-2010 8:30 AM
Another charging issue....sheesh MACI4LIFE Honda FireBlade 1 06-26-2008 8:36 AM
