Starting Problems on CBR400 RR
Old 03-02-2008, 2:21 AM
Bike(s): SP1, CBR400RR (NC23)
Rep: ajt2 is on a distinguished road (10)
Hi can anybody help me on this one.
I have a babyblade (on a J plate) which has been laid up in my garage for around 3 months without being started (silly me). Prior to that it was working fine as the last time it was started was when it was up for sale and someone came for a test ride.
I have now gone to start it and, yes you've guessed, it wont start! Now bearing in mind it hasn't been rode since that time here is a check list of things i have done:
1. Charged battery.
2. Drained old fuel from tank and replaced with new fuel.
3. Drained old fuel out from carb float.
4. Checked that plugs are sparking on turn over.
5. Checked that fuel pump is working by disconnecting from fuel rail.
The bike was on paddock stands front and back for the duration so i have no reason to suspect anything major, however i have just run out of ideas as the bike turns over but does not catch at all! i tried with the choke out and in and also with the accelerotor fully open but to no joy. On a couple of occasions it has back fired when trying to turn over which lead me to believe that fuel was being burnt in the exhaust.
PLEASE,PLEASE,PLEASE can anybody help me or shed some light on this
cheers
ajt2 is offline
View ajt2's Profile View ajt2's Gallery Find More Posts by ajt2
Old 03-03-2008, 10:27 PM
Bike(s): 03CBR954RR, 01V*Custom1100
Rep: Fisch is on a distinguished road (10)
Re: Starting Problems on CBR400 RR
How are the plugs -wet? I assume they are gapped properly and sparking sufficiently. Intake/Compression/Power/Exhaust
Air supply stopped?
Jets clogged?
Valves OK?
What is the battery votage? Does the regulator work ok?
Just trying to help you think. I don't have the smoking gun.
Fisch is offline
View Fisch's Profile View Fisch's Gallery Find More Posts by Fisch
Old 03-04-2008, 1:15 PM
Hey Fisch,
Thanks for the reply. I dont know if you know the layout of this particular blade (J-Reg) NC23 but the plugs are hard to get to in the cylinder head (or is there a simple way to get to them that i dont know?), so i had to get another plug to check the sparking.
I have been trying to start the engine with the air filter off so no airwaves blocked. i have also used a car battery to try and start but to no avail.
I am assuming if the plugs are wet it means their's fuel getting into the chambers for combustion and if their is no spark (or weak spark) that this fuel that is not being burnt off is being deposited in the exhaust can hence why i was getting backfiring earlier on in the process?
I just thought that it might be something simple that happens when you lay a bike up for a long time as it was working fine prior to this .
I wish you did have that smoking gun, as i would use it on the bike!
ajt2 is offline
Old 03-05-2008, 2:32 AM
Bike(s): 2001 CBR 929
Rep: Renegade929 is an unknown quantity at this point (4)
shoot some ether into the plug holes, i can almost guarantee you it will start..
Renegade929 is offline
View Renegade929's Profile View Renegade929's Gallery Find More Posts by Renegade929
Old 03-06-2008, 9:49 AM
Nice one!
Do you have any other ideas before i take you up on that one?
ajt2 is offline
Old 03-06-2008, 11:05 PM
That is the key part here. You need to get the plugs out. Verify their wetness (health). Spray some ether... see if it will grab. If it does... then you know you have a/ lack of fuel/ lack of flow/ timing is off/ valve is bent.
A compression check woud also be a good check. I believe they made an extension for a 10mm wrench that dropped down into the cavern they put the plugs in.
Fisch is offline
Old 03-07-2008, 9:28 PM
Originally Posted by ajt2 View Post
Nice one!
yeah ,you could try shooting the ether into the carb intakes...but the plugs would be alot better, and you could clean them first ......if the bikes was running fine before you stored it, it's not something mechanical
Old 03-08-2008, 2:11 AM
Thank you both Fisch & Renegade929,
I will try this once i get to the plugs. I did try last night to get to them (AGAIN!), but i am finding it difficult due to it's positioning and the obstacles that are in the way (you know how compact these bikes were made) even by moving the Rad forward and taking the HT coils off there appears to be a "rubber gator" that is covering the cylinder head which will not budge for love nor money so making it impossible to get to the plug caps
Enough moaning i am sure you guy's have better things to do. If you know how to overcome this problem (or anyone who has done this) then let me know otherwise i will soldier on and keep you updated on my progress.
ajt2 is offline
Old 03-09-2008, 3:36 PM
Bike(s): honda cbr900rr fireblade rrw
Rep: davey.g is on a distinguished road (10)
Hi there mate i had the same problem when i had a cbr 400 if id left it for a month or so it took forever to start if it got feul and a spark it should go and i had left mine for about 4 month and it realy took a hell of alot of turning over to get it going about 1 and a half hours
davey.g is offline
View davey.g's Profile View davey.g's Gallery Find More Posts by davey.g
Old 03-10-2008, 2:17 AM
Surffrog's Avatar
Bike(s): 1990-92 Honda CBR 400rr
Rep: Surffrog will become famous soon enough (53)
Sorry for the delay on this. I've only just seen the post. I've got and ride a cbr 400rr all the time (See my avatar). Biggest problem I ever get with starting is after washing, usually when lightly spraying water through the radiator to clean the crud out of it. Water gets back on to the top of the head and WILL find its way through the plug covers enough to make it nigh on impossible to start if I don't take it for a run straight after. It's a pain in the arse because, as you've already pointed out, there not a lot of room in there to get to the plugs.
After taking the tank off, you'll have to take off the coils. Just undo to the two mounting bolts and the whole unit will come away. Don't forget to mark which coil goes to which plug. Then pull back the rubber shield and this will give you access to the plugs. The best way to get the plugs out is by using a standard plug socket with a cut-down length of allen key to act as a drive (From memory a 10mm key drive does the trick here. Then just use a 10mm spanner to undo the plug via the allen key. This will give you the room you need to get the plug out.
Also, change the fuel filter (located just under the fuel tank on the bike's left side, under the fuel cut-off switch), it will only take about 1-2 minutes. They get clogged up after time standing around so it's good practice to replace it.
Oh, and just one more thing. I've done this so please don't think I'm insulting your intelligence, but you have checked the fuel cut off/reserve switch haven't you?
Good luck and I hope this helps
Surffrog
Surffrog is offline
View Surffrog's Profile View Surffrog's Gallery Find More Posts by Surffrog
Old 03-10-2008, 2:31 AM
Surffrog's Avatar
Hey Fisch,
One more thing. The 400's regulators love to sh*t themselves if left for a while. The only time in a year and a half that mine backfired was about 30 seconds before the regulator went bang and took out the wiring in my headlights and melting the high-beam fuse! If its died, for gods sake don't replace it with another honda unit. Get a after-market type with cooling fins!
Surffrog is offline
Old 03-15-2008, 4:07 AM
Hi Surffrog
thanks for the tips will try and let you know how i get on
ajt2 is offline
Old 04-16-2008, 5:22 AM
Surffrog's Avatar
Btw, to all of you guys with CBR 400's, we now have our very own section, so lets start posting there. Hope to see you soon.
Surffrog is offline
Old 04-16-2008, 10:57 AM
Red Rider's Avatar
Bike(s): '01 CBR929
Rep: Red Rider is a splendid one to beholdRed Rider is a splendid one to beholdRed Rider is a splendid one to beholdRed Rider is a splendid one to beholdRed Rider is a splendid one to beholdRed Rider is a splendid one to beholdRed Rider is a splendid one to behold (769)
Moved thread to the new CBR400RR section.
Red Rider is offline
Old 04-29-2008, 2:41 AM
  #15
Bike(s): CBR400RR
Rep: yellafella is on a distinguished road (10)
Hi there, I have a G Plate and I have suffered the same problem in the past
To solve it easily, I remove the tank and then use a tube leading into a bottle with fresh fuel hanging above the bike to allow a gravity feed. It seems to solve the problem.
I dont know why but it seems to be caused by an airlock from the tank to the carb.
Good Luck
yellafella is offline
View yellafella's Profile View yellafella's Gallery Find More Posts by yellafella
Old 04-29-2008, 8:14 AM
  #16
LoopyLee's Avatar
Bike(s): CBR400RRN, and a bike in bits
Rep: LoopyLee will become famous soon enough (70)
I wonder how he got on with his bike.....
I had the same problem.. turned out I had an intermittant fault on my fuel pump... so I took it out!!!! I've been running on a gravity fed system for the last 2 weeks.. the tank is connected straight to the carbs with just the inline fuel filter on..
I have ordered a new one and it should be here this week..
LoopyLee is offline
View LoopyLee's Profile View LoopyLee's Gallery Find More Posts by LoopyLee
Old 05-01-2008, 3:43 AM
  #17
Bike(s): Honda CB400 super four, & CBR900RR fireblade.
Rep: Gothy is on a distinguished road (15)
im having the same problem on a ninja 636 at college.
I've done everything meanioned here, even cleaned the carbs and jets.
spark plugs ok.
fuel pump fine.
and has a fat healthy spark.
but it just wont run.
dunno what to do, since it sounds like the same problem everything you guys suggest for the cbr400 i will try on the ninja.
Gothy is offline
View Gothy's Profile View Gothy's Gallery Visit Gothy's homepage! Find More Posts by Gothy My Map Location
Old 05-01-2008, 5:30 AM
  #18
LoopyLee's Avatar
I'd suggest testing everything more than once.. When I first test my fuel pump it worked just fine... tested it a few weeks later and it didnt work.. then we tried it a few more times, the same day, and it was working intermittantly!!!!
The new fuel pump for my blade has been paid for and is on its way to me now so I can get it fitted
LoopyLee is offline
Old 05-05-2008, 2:12 AM
  #19
Surffrog's Avatar
spark plugs ok.
fuel pump fine.
Gothy, have you checked the floats and the vacuum slides that hold the needles? Sometimes those rubbers can hide a tear in them really well!
Surffrog is offline
Old 05-05-2008, 9:30 AM
  #20
to be honest i havn't touched the top of the carbs,
I didnt think it was a problem, they seem to function fine.
Im back in on wednesday, so ill have the carbs off again, and inspect them too.
Gothy is offline
Old 05-06-2008, 1:36 PM
  #21
LoopyLee's Avatar
Fuel pump and new fuel relay now fitted (well.. I did it on Sunday) and now she runs just fine
LoopyLee is offline
Old 05-14-2008, 10:06 PM
  #22
Bike(s): 954, 400R, VT250
Rep: soupnazi is on a distinguished road (11)
Some good advice in here. I recently went through a similar episode with my NC23 project. Having not been started for the best part of 24 months it took some convincing.
I suspect you probably flooded the engine whilst attempting to start it. Keep your battery charged and keep trying it with only a little bit of choke. You'll get more backfires and in a jiffy it'll start turning over. Once it's done this it'll start easier in each subsequent attempt.
soupnazi is offline
View soupnazi's Profile View soupnazi's Gallery Find More Posts by soupnazi
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 4:10 PM.
