 1 Hour Motorcycle & Car Loans    Honda CBR's Exhaust Systems  CBR Eliminators Helmets Boots Stickers
Recommended Tyre Pressures & Oil Grade
Old 05-17-2008, 4:57 AM
Bike(s): Honda CBR400RR NC29 RRM
Rep: Tim Poole is on a distinguished road (10)
Hi Guy's & Girl's,
I'm new to the forum ive had my CBR400rr NC29 since December but haven't ridden it much as i've been away travelling, now i'm back and the weathers better i plan to ride her alot more,
I want to do an oil change on it and i don't have a manual so i'm after some info on the best Oil Grade to run in her and how much it will require
The other thing is what sort of Tyre pressures you guys running?
Also I've got to change the rear wheel bearings, has anyone else done this before, i do alot of work on cars and have pressed bearings in out of hubs with a fly press but don't currently have one, just wondered how hard they were to get out, especially if there worn
Cheers Tim
Tim Poole is offline
View Tim Poole's Profile View Tim Poole's Gallery Find More Posts by Tim Poole
Old 05-17-2008, 6:06 AM
Surffrog's Avatar
Bike(s): 1990-92 Honda CBR 400rr
Rep: Surffrog is on a distinguished road (49)
Re: Recommended Tyre Pressures & Oil Grade
Firstly, Tim. Great to have you on board.
You need a 10w40 grade oil. The amount will depend on whether you're changing the filter as well (highly recommended). Book says 2.9 litres if you don't. 3.1 litres if you do. Either way, buy four litres and keep checking it as you fill up. Mine seems to need about 3 to 3.5.
I run between 33 and 35psi front and rear. This works for me.
Generally speaking, the bearings are easy to get out. Any long, stiff, flat-drive screwdriver and a hammer will do the job without too much force needed. Just don't stay tapping the bearing in one place. Keep moving around, hit it firmly, then move directly opposite and hit it again a couple of times. If you've done a car's wheel bearings you'll find this a cakewalk.
When putting the new ones in, use a socket that matches the size of the bearings outer rim to tap them back in to their seat - don't forget the spacer tube before you put the last bearing in. Also, before you tap the last bearing home, make sure the tube is lined up by sliding the axle bolt back through the first bearing, the spacer and the last bearing.
There's also a bearing in the sprocket coupling that might need replacing.
Hope this helps. Good luck
Surffrog is offline
View Surffrog's Profile View Surffrog's Gallery Find More Posts by Surffrog
Old 05-17-2008, 10:53 AM
LoopyLee's Avatar
Bike(s): CBR400RRN, and a bike in bits
Rep: LoopyLee will become famous soon enough (53)
to the forum..
Its lovely to see another new member here with us..
LoopyLee is offline
View LoopyLee's Profile View LoopyLee's Gallery Find More Posts by LoopyLee
Old 05-18-2008, 1:41 AM
Thanks for the warm welcome guys, and the info
Code:
This i didnt know so thanks for that ill get it on order, hopefully get all the parts this week and get her running nice again.
I've got a Genuine filter coming too, 10w40.........Any Particular make?
cheers Tim
Old 05-18-2008, 6:18 AM
Bike(s): 2006 blue and yellow 1krr
Rep: ldavis is on a distinguished road (12)
REPSOL full synthetic.. seems to work fantastic in mine.. but this is a hotly debated subject..
ldavis is offline
View ldavis's Profile View ldavis's Gallery Find More Posts by ldavis My Map Location
Old 05-19-2008, 12:09 AM
Surffrog's Avatar
I agree. It most certainly is. I would do a search and then go with what feels right. You'll never get everyone agreeing on one oil.
Surffrog is offline
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 3:21 AM.
