CBR400RR Specifications
Old 06-03-2008, 4:41 PM
I'm a bird.. NOT a bloke!!!
LoopyLee's Avatar
Bike(s): Honda, Kawasaki
Rep: LoopyLee will become famous soon enoughLoopyLee will become famous soon enough (114)
History, Specifications And Technical Information
History
First manufactured in 1988 the Honda CBR400RR, or 'BabyBlade', is the smaller sibling of the Fireblade or CBR900RR series even though it preceded the 900cc Fireblade by several years. It was manufactured for the Japanese home market and from its release stormed straight to the top of the sales charts. The CBR400RR engine was a development from that of the CBR400 Aero, but had gear driven cams, an aluminium frame, a 17 inch front wheel and brand new styling complete with a twin headlamp fairing. It was referred to as either the ‘Tri-Arm’, a reference to its triangulated swingarm, or the NC23, its factory code. This domination of the Tri-Arm was continued in 1990 by the next generation of CBR400RR, the ‘L’ model, also known as the ‘Gull-arm’, or its factory designation the ‘NC29’. In spite of the superficial similarities between the Tri-Arm and the Gull-Arm, the Gull-Arm was in fact a completely new machine whose parts had much in common with the VFR400, including 17 inch wheels, front and rear. The name ‘Gull-Arm’ came from the bikes new swing arm design, derived from the, then, current race design a year after the swing arm was seen on the race track.
When the 900cc FireBlade hit the worlds markets and revolutionised the sports bike market in 1992 the Gull-Arm got the same paintwork and the FireBlade sticker on the fairing. Even though the 400 was the earlier design, it was christened the Baby Blade and went on to become probably the best selling ‘grey import’ in the UK.
Model Classifications, Dimensions And Weights
Model, Code and Production Year - CBR400RR-J (1988)
Frame Numbers - NC23-1020001 to 1036454
Engine Numbers - NC23E-1020001 to 1036510
Carburettor Number - VG04A
Wheelbase - 1370mm
Overall length - 2020mm
Overall width - 690mm
Overall height - 1110mm
Ground clearance - 120mm
Weight (dry) - 179kg
Model, Code and Production Year - CBR400RR-K (1989)
Frame Numbers - NC23-1090001 to 1098116
Engine Numbers - NC23E-1090001 to 1098123
Carburettor Number - VG04B
Wheelbase - 1380mm
Overall length - 2202mm
Overall width - 675mm
Weight (dry) - 182kg
Model, Code and Production Year - CBR400RR-L (1990 and 1991)
Frame Numbers - NC29-1000001 to 1010598
Engine Numbers - NC23E-1300001 to 1310636
Carburettor Number - VP01A
Wheelbase - 1365mm
Overall length - 1990mm
Overall width - 670mm
Overall height - 1080mm
Ground clearance - 125mm
Weight (dry) - 180kg
Model, Code and Production Year - CBR400RR-N (1992 and 1993)
Frame numbers - NC29-1050001 on
Engine Numbers - NC23E-1420001 on
Wheelbase - 1365mm
Model, Code and Production Year - CBR400RR-R (1994 - on)
Frame Numbers - NC29-1100001 on
Engine Numbers - NC23E-1500001 on
Carburettor Number - VP01B
Wheelbase - 1365mm
Ground clearance 125mm
Specifications CBR400RR-N
Type Four-stroke, dohc, in-line four cylinder
Capacity 399cc
Bore & Stroke 55.0mm x 42mm
Compression Ratio 11.3:1
Valve Train Gear Driven DOHC; 4 valves per cylinder
Cooling System - Liquid cooled, radiator with cooling fan
Clutch - Wet multi plate
Clutch operation - Cable operated
Transmission - 6-speed
Primary reduction - 2.117 : 1 (72/34)
Final reduction (sprockets) 2.600 : 1 (39/15)
Transmission - 6 speed constant mesh
Final drive chain - 102 links, split
Frame Twin spar, box-section aluminium
Front Suspension - Oil-damped telescopic forks
Rear Suspension - Single shock absorber with 3-way linkage
Front brakes - Double floating disc; 2-piston Nissin sliding callipers
Rear brake - Single solid disc; single-piston Nissin sliding calliper
Fuel tank capacity - 15.0 liters (4.0 U.S. gal., 3.5 Imp gal.)
Ignition system - Digitalized full transistor ignition
Starting system - Electric
Battery Type - YTX7L-BS
Charging system - Triple phase output alternator
Regulator/rectifier type - SCR Shorted/triple phase full wave rectification
Recommended engine oil -SAE 10W-40
Engine oil capacity at oil filter change - 3.4 litres
Idle speed - 1,300 +/- 100 rpm
Cold tire pressure (driver only, front) - 33 psi (2.25 bar)
Cold tire pressure (driver only, rear) - 33 psi (2.25 bar)
Cold tire pressure (driver & pass., front) - 33 psi (2.25 bar)
Cold tire pressure (driver & pass., rear) - 36 psi (2.50 bar)
Spark plug (standard) - NGK CR8EH-9 or equivalent
Spark plug (racing) - NGK CR9EH-9 or equivalent
Spark plug gap - 0.8-0.9mm
LoopyLee is offline
View LoopyLee's Profile View LoopyLee's Gallery Visit LoopyLee's homepage! Find More Posts by LoopyLee
Old 06-04-2008, 12:57 AM
Website Owner - AYS
.OrgOwner's Avatar
Rep: .OrgOwner has a spectacular aura about.OrgOwner has a spectacular aura about (170)
Re: CBR400RR Specifications
Awesome post Loopy - very well constructed, I've been forced to stick this thread and give you some rep points as well!
"Making it to the summit is optional. Making it back to basecamp is not."
Blog
.OrgOwner is offline
Old 06-04-2008, 1:11 PM
LoopyLee's Avatar
Thank you
LoopyLee is offline
Old 08-10-2008, 6:29 PM
Sceaf3
sceaf3's Avatar
Bike(s): 1994 Honda CBR600F3SJE & 1983 CB1100F
Rep: sceaf3 is on a distinguished road (10)
LoopyLee;
Thanks for the great information on the CBR400RR. I rode a VFR400R (NC30) for a long time on both street and track and really enjoyed the bike. A picture of the bike in in my gallery. I believe it was heavier than its inline counterpart. The VFR had an 18" rear, I believe until Honda came out with the RVR400R. Mine had a 17" Interceptor or RVR wheel. Do you know the hp comparisons between the two bikes?
Thanks,
sceaf3
sceaf3 is offline
View sceaf3's Profile View sceaf3's Gallery Find More Posts by sceaf3
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 3:01 PM.
