RE:Brake Caliper Question
Old 07-24-2008, 10:32 AM
Bike(s): in Situ Guys!
Rep: marty_400 is on a distinguished road (13)
Hiya All,
Man, I have opened up a can of worms here!
One of the front left brake pads is flopping around in the caliper for some reason.
There is definate movment of the pad, going up and down. Thats how I spotted the offending pad.
Below are my checks so far.
What Do I do next guys??!?!
Hope you can advise!
Cheers
Martin
The Problem:
It is the Front left caliper. The "In Side" Pad is moving about - all the other Pads are stuck firmly in place.
OK, the pad moves up and down. This freeplay is alot more obvious than any "side to side" Movement. Is the "Up and down" movement suppose to be allowed in a caliper?!?!?!
All the other 5 pads are stuck fast in position.
My Checks so far:
(1) When I pull the Bake Lever, the movement on the Floppy Pad goes. Ie the pad is now gripped onto the Caliper. The Brake piston itself appears to be moving ok.
(2) When I let go of the Brake lever, the Brake pad floppyness comes back again. Ie. the piston appears to be moving ok.
(3) On the Offending Caliper, the "Retaining Sprung plate" is much softer than on the Other Front Caliper. I can bend the plate back a bit, away from the pads etc. Whereas the other caliper's is firmly stuck into place.
There is definate movent in the pad up and down. Thats how I spotted the offending pad.
Cheers
Martin
marty_400 is offline
View marty_400's Profile View marty_400's Gallery Find More Posts by marty_400
Old 07-24-2008, 10:59 AM
denzee's Avatar
Rep: denzee is just really nicedenzee is just really nicedenzee is just really nicedenzee is just really nice (361)
Re: Brake Caliper Question
Sounds like one of the anti-rattle clips has come out of place. You'll have to lift the caliper off to see better. You may have to pull off the other one as well to help you see what's wrong by comparing.
denzee is online now
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 11:23 AM.
