Cooling fan Seized! Does the Rad need to come off, to take off the fan?
Old 08-26-2008, 8:56 AM
Bike(s): in Situ Guys!
Rep: marty_400 is on a distinguished road (13)
Hiya All,
NC29, CBR400rrn.
I've tried dousing in wd40, and leaving overnight - to no avail! either a Stone chip is stuck in there well and good, or the FAN is completly bageled! The fan can move a little either way. It dosesn't rotate at all.
Haynes Manual says the RAD needs to be removed, to get to the FAN.
Also, Taking off the Rad - does it route past the exhaust headers ok, or do they need to come off as well?!?!?
Hope you can advise!
Cheers
Martin
PS:
How did I find out? Was stuck in heavy traffic, and notied the temp guage itting the red zone!
marty_400 is offline
View marty_400's Profile View marty_400's Gallery Find More Posts by marty_400
Old 08-26-2008, 10:09 AM
Bike(s): 2001 CBR929RE1
Rep: MACI4LIFE will become famous soon enough (65)
Send a message via ICQ to MACI4LIFE
Re: Cooling fan Seized! Does the Rad need to come off, to take off the fan?
i hear my fan making a little more noise than usual. i think my fan is on it's way out as well
we'll find out how hard it is for a 929 fan to come off.
MACI4LIFE is offline
View MACI4LIFE's Profile View MACI4LIFE's Gallery Find More Posts by MACI4LIFE
Old 08-27-2008, 6:38 AM
Surffrog's Avatar
Bike(s): 1990-92 Honda CBR 400rr
Rep: Surffrog will become famous soon enoughSurffrog will become famous soon enough (133)
Originally Posted by marty_400 View Post
Hiya All,
NC29, CBR400rrn.
Cheers
Martin
PS:
You might be able to get away with taking the bottom bolts out and loosening the top ones. However, this depends on how seized the fan bolts are.
Either way, taking the radiator out isn't that much of a pain and will get past the head without drama. Down on the left side of the bike near the gear peg is the drain screw (check your manual to locate the exact screw). Undo this screw all the way (make sure you've got a drain tray to catch all the fluid). Once done, take off the bottom side fairings (both sides makes life easier), then remove the pipes from the radiator. After that, you've only got the top and bottom bolts hold the radiator in. Just remember to handle with care as it's really easy to damage it. Same goes for when you're removing the fan from the radiator.
Oh, and don't forget to unplug the fan first
Good luck
Surffrog is offline
View Surffrog's Profile View Surffrog's Gallery Find More Posts by Surffrog
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 3:14 PM.
