big problems help
Old 08-28-2008, 7:36 AM
Bike(s): cbr400rr nc23
Rep: DNGRSDAZ is on a distinguished road (10)
big problems help
hi everyone as some of you know i recently posted about servicing my nc23 triarm i started with plugs witch according to the haynes manual were ngkcr9eh9 with a single feeler on the electrode and threaded so far with a countersink on them but the plugs i removed from my bike were cr9ek with 2 feelers on the electrode and threaded all the way down so i presumed the plugs that were in were wrong so i changed them to the cr9eh9 from the haynes, bike started first time and idled perfectly also revved fine so decided to take for a quick ride make sure it was ok, but problems started as i picked up pace around 50mph the bike felt somehow rougher and vibrated the seat more and when i opened the throttle it sounded gruntier and as i accelerated the was a whistleing sound that happened everytime i accelerated past 50mph almost like a turbo whine so i headed home, when i got home there was oil splattered on the inside of the screen and down the forks but couldnt see where it was coming from so decided straight away to change the plugs to the ngkcr9ek got some new ones fitted them started up ok idled a little bit rough not much took it to supermarket it felt rough no power in the bike the whistleing is still there and it sounds rough and is jolting like mad at low revs and stalled on me twice while about to set of from still and now the engine sounds rough with a tapping noise please help hope i havent killed her
DNGRSDAZ is offline
View DNGRSDAZ's Profile View DNGRSDAZ's Gallery Find More Posts by DNGRSDAZ
Old 08-28-2008, 5:12 PM
I'm a bird.. NOT a bloke!!!
LoopyLee's Avatar
Bike(s): Honda, Kawasaki
Rep: LoopyLee will become famous soon enoughLoopyLee will become famous soon enough (114)
Re: big problems help
according to the web sites I've looked at the spark plugs for your bike should be CR8EH-9 NGK Standard Spark Plug or equivilant
Some days you're the bug; some days, the windshield!
Somewhere Else
LoopyLee is offline
View LoopyLee's Profile View LoopyLee's Gallery Visit LoopyLee's homepage! Find More Posts by LoopyLee
Old 08-28-2008, 5:25 PM
WYSIWYG
macca9540's Avatar
Bike(s): 2003 954 fireblade
Rep: macca9540 will become famous soon enough (68)
If you've got oil leaking and spraying onto the forks and screen I would be finding that problem post haste. Oil, tyres and road do not mix all that well if you know what I mean.
macca9540 is online now
View macca9540's Profile View macca9540's Gallery Find More Posts by macca9540
Old 08-28-2008, 5:38 PM
cheers loopy cr8eh9 are the standard plug then the racing plug is cr9eh9 but the ones originally in were cr9ek i put them back in and it runs ok now and ive just found what the oil is i have damaged my radiator when i changed the plugs and its a green fluid spraying out when running so ive patched it with a bit of bluetackits slowed down will have to get another radiator of ebay(is the fluid just normal coolant) but i have no idea what the whistleing through the rev is and the clicking noise wich only happens when the bike is warm(after a run)
DNGRSDAZ is offline
Old 08-28-2008, 6:05 PM
LoopyLee's Avatar
Chewing gum is better as it dries out after a bit making a nice hard lump
Somewhere Else
LoopyLee is offline
Old 08-28-2008, 6:06 PM
LoopyLee's Avatar
Its a mix of water and anti freeze in your radiator.. your manual will tell you what mix you need for it
Somewhere Else
LoopyLee is offline
Old 08-28-2008, 7:47 PM
cheers loopy your a fountain of knowledge ill sort out chewing gum tomoz till i get radiator, if i feel her get worse over next few weeks ill cut losses and book her in for the once over thanks again
DNGRSDAZ is offline
Old 08-29-2008, 4:01 AM
Surffrog's Avatar
Bike(s): 1990-92 Honda CBR 400rr
Rep: Surffrog will become famous soon enoughSurffrog will become famous soon enough (133)
The whistling could be the sound of the coolant escaping from the radiator. Also, If the coolant manages to find its way to the plugs it might create a misfire/poor running.
As for the clicking sound, check your oil level. Mine does that clicking sound if the level drops even by only a quarter!
Surffrog is offline
View Surffrog's Profile View Surffrog's Gallery Find More Posts by Surffrog
Old 08-29-2008, 2:09 PM
LoopyLee's Avatar
gush gush
Somewhere Else
LoopyLee is offline
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 2:59 PM.
