Radiator Fan
Old 07-01-2009, 10:49 PM
Bike(s): CBR 400
Rep: Rhyees is on a distinguished road (10)
Radiator Fan
Hey Guys,
I have found that when i have taken my bike for a long cruise into the city and there is quite some traffic the bike heats up and i have not heard the Radiator fan working at all.
I have checked the Thermostat and it all works fine and opens up.
The temp gauge also was perfectly fine. Just the fan doesnt seem to turn on at all.
Any ideas.?
The Fan looks in good condition. Just don't know if its working or not.
Rhyees is offline
View Rhyees's Profile View Rhyees's Gallery Find More Posts by Rhyees
Old 07-02-2009, 3:28 AM
Bike(s): NC29 Honda Babyblade
Rep: garyboy_palaboy is on a distinguished road (36)
Re: Radiator Fan
Originally Posted by Rhyees View Post
Hey Guys,
Any ideas.?
check your connector pins which goes to the thermostat and fan. it might have a loose contact or burnt wires.
this happened to me before, so check every wires very well....
garyboy_palaboy is offline
View garyboy_palaboy's Profile View garyboy_palaboy's Gallery Find More Posts by garyboy_palaboy
Old 07-02-2009, 3:37 AM
Bike(s): CBR 400
Re: Radiator Fan
Ok sweet,
Will check them both. I checked the connectors on the fan and it looked ok. Could also possibly be that the fan has seized. But it still spins freely.
Rhyees is offline
Old 07-02-2009, 5:22 AM
Re: Radiator Fan
Ok sweet,
remove the whole fan assembly and try to connect it DIRECTLY to the battery. if it spins, its ok, if not then its busted.
you can't really determine if its working or not just by relying the fan spins freely.
Old 07-02-2009, 8:22 AM
Bike(s): CBR 400
Re: Radiator Fan
Yeah i figured that would be the case.
I'll be checking this out shortly!.
Rhyees is offline
Old 07-09-2009, 12:37 AM
Surffrog's Avatar
Bike(s): Kawasaki ZX10r
Rep: Surffrog has a brilliant futureSurffrog has a brilliant futureSurffrog has a brilliant futureSurffrog has a brilliant futureSurffrog has a brilliant futureSurffrog has a brilliant futureSurffrog has a brilliant futureSurffrog has a brilliant futureSurffrog has a brilliant futureSurffrog has a brilliant futureSurffrog has a brilliant future (1935)
Re: Radiator Fan
No one seems to have mentioned this yet, but you should check the sender unit in the radiator. Everything might well be working perfectly but if the sender unit has packed up then the fan won't switch on.
One more thing: the sender unit might be fine but if there is insufficient water in the radiator the fan still won't come on because the sender won't get hot enough to engage.
Surffrog is offline
View Surffrog's Profile View Surffrog's Gallery Find More Posts by Surffrog My Map Location
Old 07-09-2009, 12:55 AM
Bike(s): CBR 400
Re: Radiator Fan
Cheers Surffrog,
I'll check that out also. Going to work on the bike now!.
Is the sender unit easy to get to.?
Rhyees is offline
Old 07-09-2009, 1:14 AM
Surffrog's Avatar
Re: Radiator Fan
Cheers Surffrog,
Well, you'll need to take the fuel pump out. It's located under the carbs but you don't need to take them out. What you may well find is that the rubber mounting used to hold the pump in place will have split by now. But don't fear. When you put it back, place it as close to its original position and strap it up with the mechanic's best friend - the cable tie. I use two of them just to be on the safe side.
With the pump out you're looking for just one wire with a single connector on the end.
Surffrog is offline
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 7:50 PM.
