Service for my bike and i need opinions
Old 07-14-2009, 3:58 AM
Rep: jonny85 is on a distinguished road (10)
hey guys so im servicing my bike this week or the coming week and i currently have an 1988 NC23J cbr 400 tri arm and i need some tips
spark plugs NGK iridium or NGK normal ones?
Engine Oil which brand and what type apart from 4 cylinder oil of course 5w50? and ii make sure its hi performance?
should i change the chain? and clutch?
and it seems that the previous owner bought a viper exhaust can for it but it wasnt originally for the NC23 and he changed the attachment by welding so the can hangs a bit loose. should i wait a bit more then change the downpipes? or just do it now? and get a new can too?
thanks
jonny85 is offline
View jonny85's Profile View jonny85's Gallery Find More Posts by jonny85
Old 07-14-2009, 5:50 AM
Bike(s): 1993 fireblade rr-p
Rep: Milzy has a spectacular aura aboutMilzy has a spectacular aura about (184)
Re: Service for my bike and i need opinions
spark plugs NGK iridium or NGK normal ones? iridium... they last longer and are more efficient IMO
Engine Oil which brand and what type apart from 4 cylinder oil of course 5w50? and ii make sure its hi performance? i use castrol normally, but dont have a preference as long ass its semi synthetic
should i change the chain? and clutch? only if they are needed! remember, if you do the chain, you should do the sprockets too. are there any tight spots on the chain or worn teeth on the sprockets?
and it seems that the previous owner bought a viper exhaust can for it but it wasnt originally for the NC23 and he changed the attachment by welding so the can hangs a bit loose. should i wait a bit more then change the downpipes? or just do it now? and get a new can too? ?????? look on ebay or the like for a cheap full system, thats what i'd do! budget £300+
thanks
heya! see notes in red!
Milzy is offline
View Milzy's Profile View Milzy's Gallery Visit Milzy's homepage! Find More Posts by Milzy
Old 07-14-2009, 9:28 AM
hey thanks
ye about the exhaust i'll do it after i fix my current problem which is currently the bike is stalling after a while on idle and sometimes i here clunking when its on idle from the engine or something, maybe carb timings or springs, not sure or a dirty fuel system? yesterday i raised it a bit and saw black puffs so theres dirt probably involved.
jonny85 is offline
Old 07-14-2009, 3:21 PM
Bike(s): CBR400RR
Rep: Kid-Dynamite is on a distinguished road (10)
hey thanks
Hi mate, my bike used to stall/cut out on idle when I had the lights on, brought a new battery and it seems to have resolved the issue. Not sure if this has something to do with yours stalling though
Kid-Dynamite is offline
View Kid-Dynamite's Profile View Kid-Dynamite's Gallery Find More Posts by Kid-Dynamite
Old 07-14-2009, 3:27 PM
just came back from a quick visit to the mech and he said its the carbs that need cleaning so temporarily until i fix a date with him he raised the idle revs for now for it to hold
jonny85 is offline
Old 07-15-2009, 3:08 AM
Surffrog's Avatar
Bike(s): Kawasaki ZX10r
Rep: Surffrog has a brilliant futureSurffrog has a brilliant futureSurffrog has a brilliant futureSurffrog has a brilliant futureSurffrog has a brilliant futureSurffrog has a brilliant futureSurffrog has a brilliant futureSurffrog has a brilliant futureSurffrog has a brilliant futureSurffrog has a brilliant futureSurffrog has a brilliant future (1992)
Personally I wouldn't bother with the expensive plugs because unless you do track sessions you won't really notice the difference.
With regard to the oil a 5w40 or, as the book says, a 10w40 is the way to go. Mobile (yes car oil) do a nice semi-synthetic that's reasonably priced and does a good job. I've been using it for three years without issue but I also change it fairly regularly with a filter each time.
Unless the chain has been allowed to get rusty and has worn out its links, just take it off the back cog and drop it into a tray of kerosine or WD40. Wash it throughly and remember to move the links through their full movement back and forth to free off the grit that gets between them. Don't forget to wash down the cogs, too. When you've rotated through the whole chain, wipe it down with a cloth, relocate and either lube the chain with chain wax (far too messy for me) or fresh WD40.
Surffrog is offline
View Surffrog's Profile View Surffrog's Gallery Find More Posts by Surffrog My Map Location
Old 07-15-2009, 9:55 AM
Bike(s): 2006 blue and yellow 1krr
Rep: ldavis is just really niceldavis is just really niceldavis is just really niceldavis is just really nice (396)
DO NOT USE WD40 for lube.. it will dry out the o/x rings and cause premature wear on your chain. i use wd40 to clean my chain.. find a good spray lube. i use maxxis chain wax. but any of them work pretty well
ldavis is offline
View ldavis's Profile View ldavis's Gallery Find More Posts by ldavis My Map Location
Old 07-16-2009, 3:37 AM
Surffrog's Avatar
Well, I used it for years on my 400, which I used nearly every day, as have quite a few others I know, without any issues at all. The only thing I would add is make sure you check the chain regularly and give it a spray once every week or two.
Surffrog is offline
Old 07-18-2009, 3:16 PM
Bike(s): Yamaha Chop --cbr400 rr nc23 up for sale
Rep: brendan is on a distinguished road (10)
hi there all i'm going to give my baby a service next week and i just wanted to know what oil ans plugs to use for my nc23rr ?? i live in the uk if that makes a difference
brendan is offline
View brendan's Profile View brendan's Gallery Find More Posts by brendan
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 12:09 PM.
