Originally Posted by brendan thanks I've tried a new horn on it and that don't work
and when i push the switch it doesn't seam to do any think
what do i do if its my switch ?? |
It's probably just dirt across the contacts or a dodgy wire. They've been in situ for god knows how many years without having been cleaned (in the case of the switch contacts). Take the thing apart, being careful not to lose any springs, screws, etc, and clean the contacts. If the problem is the switch that should be job done.
But first, I would stick a volt meter across the switch and try the switch before taking it apart. That may help help cut down the work load.
