Main fuse blowing instantly all the time??? - Honda Motorcycles - FireBlades.org
Honda CBR400RR Discuss the Honda CBR400RR in this section. This part of fireblades also covers the Honda CBR 250 and CBR 125.
post #1 of 10 Old 07-31-2010, 10:38 AM Thread Starter
I have totally stripped my nc23 down and have put the engine back in and now ran the loom. As soon as I connect the main relay the fuse blows instantly.
I've checked the wire running to the regulator and that hasnt been earthed and the other wire going to the ignotion switch and that hasnt been earthed.
So the only two wires connected to the fuse arent earthed, yet as soon as its connected the fuse blows intantly.
Any suggestions?
It's doing my head in!!!!!!!
steppinlevels is offline
post #2 of 10 Old 07-31-2010, 11:01 AM
Reputation Power: 8
Re: Main fuse blowing instantly all the time???
Any suggestions?
this may sound like a stupid question, but did you try and earth them.
you have to have a short somewhere, it just a matter of finding it, slow i know but it has to be done,
clem3 is offline
post #3 of 10 Old 07-31-2010, 11:14 AM Thread Starter
Earthing what? the two lives to the ignition and regulator? What will that achieve, its blowing the fuse before i even earth them.....
post #4 of 10 Old 07-31-2010, 11:21 AM
Sideshow bob's Avatar
Images: 12
Reputation Power: 137
Send a message via MSN to Sideshow bob
Any suggestions?
when I had this problem I disconected everything at the connector plugs.... then one by one connected them back up... as soon as the fuse blew... I double checked by removing all connectors again and just connect the plug that caused the fuse to blow..
although I been told since this is not a good idea* I soon narrowed the possibilitys down and quickly sorted the fault
*dunno why
As long as I fall, I don't hit the ground. As long as I fall, I'm safe & sound.
Sideshow bob is offline
post #5 of 10 Old 07-31-2010, 11:31 AM Thread Starter
*dunno why
Thanks, although if it is a connector plug, what do i do then, make sure all the connections there are as they should be? what did yours turn out to be in the end?
post #6 of 10 Old 07-31-2010, 11:37 AM
Images: 12
if it blows with nothing plugged in it should be a short in the main harness... if its one of the plug cut it out and replace
mine turned out to be a switchgear solder point (just*) touching on the bars
*even loosening the bolt stopped the short
post #7 of 10 Old 07-31-2010, 11:41 AM Thread Starter
Will have a crack at it now, cheers
post #8 of 10 Old 07-31-2010, 12:58 PM
Images: 6
If you have just put the engine back in i would double check around all the mounts, check that you have not traped any wires, and go through all connections to the engine,
What goes around, comes around.....
RICK-ITFC is offline
post #9 of 10 Old 07-31-2010, 1:43 PM Thread Starter
Ok, when i connect the neutral switch it blows, so i've left that off for the time being, and also, when i engage the clutch switch, it blows instantly also.
What should i do?
post #10 of 10 Old 07-31-2010, 3:57 PM Thread Starter
Ok, so it was the relay, it was sending power up and out of the clutch switch so engaging that creates the short, and the neutral switch runs off the same diode, making that short too. So new relay on order, hopefully, that does it
Go Back   Honda Motorcycles - FireBlades.org > Honda Motorcycle Models > Honda CBR400RR
Human Verification
Search tags for this page
98 shadow blowing main fuse keeps
bike keeps blowing fuses
effects of blown fuse in motorcycles
main fuse blown on motorcycle
main fuse keeps blowing motorcycle
motorcycle blowing main fuse
motorcycle fuse keeps blowing
motorcycle keeps blowing main fuse
motorcycle main fuse blowing
motorcycle main fuse keeps blowing
Keep blowing a Fuse !!!????? --> '01 CBR600F4i DC-F4i Honda CBR 600 14 08-28-2009 2:50 PM
Katana 750 Fuse Blowing james30263 Suzuki Motorcycles 2 09-17-2007 8:29 PM
F3 master fuse keeps blowing mulluthuntur Honda CBR 600 8 06-29-2007 8:05 AM
f4i blowing fuel pump fuse E_RacK Honda CBR 600 12 06-07-2007 11:50 PM
Help, my fuse keeps blowing! tommytcchan General Discussion 3 03-04-2007 8:35 PM
