throttle sticking on old cx 500 custom
Old 05-22-2006, 9:30 PM
Bike(s): 1982 honda cx 500
Rep: mattfinn is on a distinguished road (10)
my throttle will open but wont close the whole way... just happened while i was riding... gave it some gas and opened it up a lot... then it started sticking and wont return all the way closed on its own...
any suggestions?
thanks
mattfinn is offline
View mattfinn's Profile View mattfinn's Gallery Find More Posts by mattfinn
Old 05-22-2006, 10:01 PM
Bike(s): 2008 CBR1000RR, '96 RS125
Rep: Latebraking will become famous soon enough (50)
Send a message via Yahoo to Latebraking
Re: throttle sticking on old cx 500 custom
How old are the cables? Old ones fray internally and the sheathing corrodes along with the cable. Are they routed properly (shop manual for reference?) Is there any slack in the cables? What about the throttle grip? Any sand or built up crap trapped between it and the handlebar? If all that checks out then you gotta take a look at the linkage and check how it moves without the cables hooked up to it.
Latebraking is offline
View Latebraking's Profile View Latebraking's Gallery Find More Posts by Latebraking
Old 05-22-2006, 11:06 PM
G-Force Junkie's Avatar
Probaly the cables, but check the linkages around the carbs (two right?, that this is a sideways twin as I remember) Unhook the cables at the carb and work the carbs by hand, you will be able to isolate it if is the carb or cables. If its the carbs, pull the slides out and see if they are gummed or varnished up or the springs gone flat. For the cables unhook both ends, make a little funnel round the top of one with duct tape, and shoot a crap load of WD 40 in there and pull the cable in and out untill you see WD40 coming out the bottom alog with black gunk. Once its clear, you can leave it, or run a little oil down there for lube, engine oil will work fine if its all you got. If the actual cables are frayed or the liner of the cable beat up, they are going to have to be replace.
G-Force Junkie is offline
Old 05-23-2006, 2:20 AM
i believe the cables are still original... how can i tell if they are frayed? also how do i tell if there is gunk in the throttle grip? thank you for helping me out because i am just starting to learn about all this... i will also try the wd40 through the cable.
mattfinn is offline
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 4:21 AM.
