1300 VTX needs help
Old 11-17-2006, 11:58 AM
Bike(s): 750 Honda shadow, 1300 VTX
Rep: snakeg is on a distinguished road (10)
1300 VTX needs help
Hello, first let me say this is my first post to the site, but have enjoyed reading the post made by others. Now, can someone answer my problem? I enstalled a national cycle light bar on my 1300vtx, and wired it according to the instuctions, and used the power supply for the spot lights from the low beam power source to the headlight. After completing all this, I now have no neutral light, no temperature light, and the bike will not even try to start. I disconnected all the wirring that I had connected and still have no neutral light, or temperature light, and the bike does not make even a click when I press the start button. The tail light, headlight, horn and other stuff works but that's it. The battery seemed to be charged, but I now have it out and hooked to a charger just in case. If the headlight and horn seem strong, could the battery be weak enough that the nuetral light will not come on or the bike even try to start? Thanks in advance.
snakeg is offline
View snakeg's Profile View snakeg's Gallery Find More Posts by snakeg
Old 11-17-2006, 1:54 PM
abtech's Avatar
Bike(s): 2007 RC51
Re: 1300 VTX needs help
Sounds like you blew a fuse. There should be some info in the owners book regarding what fuse controls those items.
abtech is offline
Old 11-17-2006, 2:11 PM
Red Rider's Avatar
Bike(s): '01 CBR929
Rep: Red Rider is a splendid one to beholdRed Rider is a splendid one to beholdRed Rider is a splendid one to beholdRed Rider is a splendid one to beholdRed Rider is a splendid one to beholdRed Rider is a splendid one to beholdRed Rider is a splendid one to behold (769)
on the fuse. Did you disconnect the battery before wiring the light bar?
Red Rider is offline
Old 11-17-2006, 6:34 PM
Doorbell broke, please sound fog horn!
leelover's Avatar
Bike(s): 06 FJR1300
Rep: leelover is just really niceleelover is just really niceleelover is just really niceleelover is just really nice (371)
what town are near in e. Tenn?
Dumb question time: Did you check your kill switch? It's gotten me several times!
leelover is offline
View leelover's Profile View leelover's Gallery Find More Posts by leelover
Old 11-18-2006, 7:01 AM
I have checked the main 30 amp fuse and also the sub fuses in the fuse panel which holds six fuses and a diode and they all check ok.
snakeg is offline
Old 11-18-2006, 7:06 AM
I did not disconnect the battery before wirring the light bar, I did however take the battery out after all this happened and charged it to make sure that a weak batttery was not my problem. Do you know of any other fuses hidden somewhere on the bike other than the 30 amp main and the six sub fuses in the fuse panel? Man! I am lost!
snakeg is offline
Old 11-18-2006, 7:14 AM
I am in Kingsport which is located in the extreme North East of Tennessee. I did attempt to check the kill switch and as best as I can tell it is ok. When the kill switch died on you did it affect your neutral light from comming on? And, no, it is not a dumb question when directed to me especiallly. I always look for more complicated reasons and overlook the simple ones, which is what I hope is my problem is now.
snakeg is offline
Old 11-18-2006, 7:54 AM
abtech's Avatar
Bike(s): 2007 RC51
I don't think he means his kill switch died, rather he meant that it was turned off and he wasn't aware of it when he tried to start the bike. Common situation really . . .
There may be an inline fuse on your bike somewhere. Do you have a wiring diagram? That would help you trace the common element for the items that aren't working on the bike. Also, is there a tipover switch on the VTX? I would bet there is a clutch switch and kickstand switch as well. These can be designed to kill the engine circuits which may share common wiring with other components.
abtech is offline
Old 11-18-2006, 11:50 AM
leelover's Avatar
Bike(s): 06 FJR1300
you are right again Mr. abtech!
Good idea on the tip over switch, and the rest.
I would look over anything that you touched during your modification.
Seems like any time you make a modification "something" happens!
leelover is offline
Old 11-18-2006, 5:22 PM
Well, I think I found my problem, or at least it will run now and I have the nuetral light. I finished installing the light bar, and a drive shaft cover, hywaybars, fats windshield and lowers, and topped it all off with the front fender trim that looks like a grill or bumper. Then to celebrate just got bac from a three and one half hour ride with my friends. Man, those lowers sure knock off a lot of wind! Well worth the money in cold weather. Thanks to all who replied and hopefully I will be able to help someone else some time. Thanks again and safe riding.
snakeg is offline
Old 11-18-2006, 5:49 PM
abtech's Avatar
Bike(s): 2007 RC51
ummm what was the problem?
abtech is offline
Old 11-18-2006, 7:57 PM
After checking each switch and relay I found a loose connection in the neutral switch wire where it connects in the wiring harness under the drivers seat. I was so releived and happy over getting it fixed and going for a ride that I forgot to mention what I had found. Glad the bike is better, now maybe I can get a nights sleep without going over possible causes in my mind for half the night. Thanks again for all your help.
snakeg is offline
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 11:33 AM.
