| VTX 1300 wiring problems... All, Here is a good one for ya... I did a lot of work to my bike recently and one of the things I did was to replace the chrome switch covers on the handlebars. Well, as I found out, the opening for the start switch was a bit too small and what would happen is when I would go to start the bike, the button would stay pushed in, because it was stuck, and the starter would stay engaged. This happened a few times and I didn't catch it unit after the fact a few times unfortunately. Well, now I am having problems starting the bike. Both times I have been at the gas station filling up and I would go to start the bike. . . Turn the bike ignition switch on, my instrumentation would light up, make sure I am in neutral, press the start switch and whammm. Nothing. I would hear a click, and then my instrumentation lights, or tank lights, would go out (not dim, but out). Come time find out, if I were to kick or tap the starting relay, my lights would come back on and I could give the engine another start (which would only result in another click and then the instrumentation would go out again). At first I thought the problem might be just the starting relay, but when I tried to jump the switch and connect the starting leads and the battery leads, the engine wouldn't start either. So my question is this...what the hell is it? All of my fuses are fine and my wiring I am sure is good. I am changing the starting relay today and that should tell me a lot, but if not, does anyone have any suggestions? Justin |
