| 1982 CM250C rev when clutch pulled in i have been working on this bike trying to get it ready to go for summer (which is already here). anyway i have cleaned the carb out and got it to run. it will idle and runs just fine down the road. but when you pull in the clutch to slow down or shift the engine will rev up on its own. eventually it goes back to idle. also depending on how the carb is adjusted it will rev up on its own as well. i have played with the carb settings and have not come up with anything that works, so maybe more tinkering with it or if anyone has any tipe that would be appreciated. thanks |
