Issue after clutch plates and springs replaced
Old 09-26-2008, 11:01 AM
Rep: dcp3450 is on a distinguished road (10)
I replaced my clutch plates and the springs on my 2004 Honda Shadow 600 Deluxe. When I did the work I used the required Honda tool and followed the service manual I ordered from Honda. The only thing the manual stated I didn't do was replace the spring washer.
My problem is this: after I replaced the plates and springs I reattached the clutch cable. Now there is no resistance on the clutch. I have the clutch cable adjusted all the way out and I can still move the arm on the case with my hand. It seems the plunger isn't hitting the pressure plate bolted to the springs. I reviewed the directions and I did everything right.
Could that spring washer cause this issue even though its not that thick and i can turn the "plunger" all the way out?
The manual said to tighten the pressure plate down to 9 ft pounds. Should I loosen the pressure plate until it touches?
This is the only thing keeping me off the road. Any help would be great.
dcp3450 is offline
View dcp3450's Profile View dcp3450's Gallery Find More Posts by dcp3450
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 3:55 AM.
