1985 Honda Shadow Fuel Pump Problem
Old 01-09-2009, 9:09 PM
Rep: famousonea is on a distinguished road (10)
i was wondering if anyone knew about fuel pumps on honda shadow motorcycles. I have replaced the world. i have replaced the sub fuel take and all of the filters. i also put in a new fuel pump and relay. the problem is that the fuel pump is not working. i think it is a problem with the electiricty going to the fuel pump. the bike will turn over but not start and no fuel comes out. Brand new battery as well
bike is a 1985 honda shadow vt700c
famousonea is offline
View famousonea's Profile View famousonea's Gallery Find More Posts by famousonea
Old 04-20-2009, 8:59 PM
Bike(s): 85 Shadow VT 1100
Rep: Caledan is on a distinguished road (10)
Re: 1985 Honda Shadow Fuel Pump Problem
Issue with my 85 Shadow vt1100, fuel pump died & the local dealer in Essex, Vt. can't get the part from Honda, too old. Any suggestions as to where I can order one? I know this may not be posted in the right area. Sorry!
Caledan is offline
View Caledan's Profile View Caledan's Gallery Find More Posts by Caledan
Old 05-29-2009, 2:47 AM
Bike(s): 85 Shadow VT1100
Rep: fox74 is on a distinguished road (10)
I have 85 shadow vt1100 , I am not sure the wiring is the same on 750, but here it is, The fuel pump relay turns off the fuel pump when the engine is not runing, let do some trouble shooting , disconnet the fuel pump wire from the harness and connect the fuel pump directly to the battery, on my bike green wire is the ground and Black/blue is positive. The pump should come on if the carb is empty the pump would click for awhile then stops. Now you should be able to start your bike if fuel was the problem. If you have changed the fuel pump relay the problem is with the relay is not getting pulses from the ignition unit which is the middle wire of the relay. See you can start your bike first then reconnect the fuel pump to the harness see how things goes. If the carb is empty pulses from the ignition is not enough to run the pump and start the bike. please note the pump while the bike is runing click only every few seconds the replace the used fuel. let me know if I can help more
fox74 is offline
View fox74's Profile View fox74's Gallery Find More Posts by fox74
Old 05-29-2009, 3:32 AM
Caledan try ebay.com I saw many for acution.
fox74 is offline
Old 05-29-2009, 6:18 AM
Thanks for the help. I got the fuel pump and now I am searching for the fuel relay switch. I have found a few for a 2001 Saber 1100 but wasn't sure if I could use it, so I am still looking.
Caledan is offline
Old 05-29-2009, 12:49 PM
Caledan what is the problem with your bike ?, have you read my post? more often there is nothing wrong with the relay, if the bike does not start it is because there is not any fuel in the carb , this could happen if the bike was not started for few months.
fox74 is offline
Old 06-15-2009, 9:30 PM
Bike still at shop. Shop tested old pump on another bike identical to mine, his bike wouldn't start with my old pump then they put my new pump on his and his started. They tried his pump on my bike & it wouldn't start then they put my new pump back on & the bike still won't start.
I am having hard time finding the fuel relay switch. I have seen a few for newer models - Sabre 1100 & Spirit 1100. Are the switches compatible?
Caledan is offline
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 3:23 AM.
