84 Honda Shadow Vt 700 running HOT!
Old 04-21-2009, 3:09 AM
Bike(s): 1984 Shadow VT 700
Rep: jonber44 is on a distinguished road (10)
I recently bought a 1984 Honda Shadow 700, and I noticed that it runs really hot after 5 minutes of riding. THe needle hovers near the red zone in the heat guage, but the fan seems to work, and the coolant reservoir is topped. I have not seen what it does on the freeway, but only while driving on city streets. Any ideas why?
jonber44 is offline
View jonber44's Profile View jonber44's Gallery Find More Posts by jonber44
Old 04-21-2009, 3:44 AM
WyoJames's Avatar
Bike(s): 2006 CBR 1000RR
Rep: WyoJames has a brilliant futureWyoJames has a brilliant futureWyoJames has a brilliant futureWyoJames has a brilliant futureWyoJames has a brilliant futureWyoJames has a brilliant futureWyoJames has a brilliant futureWyoJames has a brilliant futureWyoJames has a brilliant futureWyoJames has a brilliant futureWyoJames has a brilliant future (1880)
Re: 84 Honda Shadow Vt 700 running HOT!
Have you tested your thermostat?
WyoJames is offline
Old 04-21-2009, 11:36 AM
Not yet. I just got a copy of the clymer manual, and will try that next. DO bikes in general run hotter on city streets? I am guessing yes, but not this high, so the thermostat (I am hoping) is the problem. Thanks!
jonber44 is offline
Old 04-21-2009, 11:39 AM
Bike(s): CBR1000RR8
Rep: Bonefish will become famous soon enoughBonefish will become famous soon enough (105)
Bike will definitely run hotter in traffic than on the open road. My blade runs at around 80cel on the open road and upto 108cel in traffic.
Bonefish is offline
View Bonefish's Profile View Bonefish's Gallery Find More Posts by Bonefish My Map Location
Old 04-21-2009, 2:27 PM
Is there a way/adjustment to keep it cooler in stop and go traffic? I plan to drive freeways more, obviously, but there are times when stop and go, 2nd and 3rd gear operations will be necessary for periods of time. Don't want to overheat!
jonber44 is offline
Old 07-06-2009, 11:31 PM
Bike(s): 85 shadow vt700c
Rep: reefkprZ will become famous soon enough (67)
I have an 85 vt700 and I can idle it all day and it wont over heat or even approach the top end of the heat zone, (its still a work in progress) the fan kicks in and cools it about halfway up the heat dial. if its not cooling down with the fan running your radiator maybe partially plugged, or as some one else mentioned maybe the thermostat is faulty. I'm still a noob with bikes but those are the things I would check. good luck.
reefkprZ is offline
View reefkprZ's Profile View reefkprZ's Gallery Find More Posts by reefkprZ
Old 07-07-2009, 9:24 PM
Thanks. I am suspecting the thermostat, but will update with solution soon. Have fun on the 85 VT700!
jonber44 is offline
Old 07-17-2009, 12:39 AM
Any progress on the high temp?
reefkprZ is offline
Old 09-10-2009, 1:18 PM
Bike(s): VT-700 Shadow
Rep: mahley54 is on a distinguished road (10)
I recently had to pull out the thermostat to stop my '85 VT-700 from over heating. Would like to find a cheap replacement, Bike Bandit wants $34.44.
mahley54 is offline
View mahley54's Profile View mahley54's Gallery Find More Posts by mahley54
Old 09-10-2009, 1:30 PM
VT-700 rear cylinder spark cuts out after running 5 minutes, but runs fine for 5 min. after a long cool down. Have subsituted another coil same results. Is it possible the magnetic pickups could cause this?
mahley54 is offline
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 1:50 AM.
