carb questions for 82 honda cm250c
Old 05-12-2009, 10:15 PM
Bike(s): 85 suzuki gs700es
Rep: sparkmaster123 is on a distinguished road (10)
i am wondering what kind of options i would have for these carbs. i recently found out that they no longer make the rebuild kits for that carb because it is not an original honda part. so i was wondering if anyone knew any other carbs that would bolt to it. ior any way to get my original one restored. any suggestions would be much appretiated. thanks
sparkmaster123 is offline
View sparkmaster123's Profile View sparkmaster123's Gallery Find More Posts by sparkmaster123
Old 05-14-2009, 11:05 PM
Jetpilot07's Avatar
Bike(s): 2007 CBR1000RR
Rep: Jetpilot07 is a splendid one to beholdJetpilot07 is a splendid one to beholdJetpilot07 is a splendid one to beholdJetpilot07 is a splendid one to beholdJetpilot07 is a splendid one to beholdJetpilot07 is a splendid one to behold (691)
Re: carb questions for 82 honda cm250c
maybe you could tear them apart and get lucky enough to save everything in there....unless it has the old brass or aluminum floats......
GENERAL ROBERT E. LEE
Jetpilot07 is offline
Old 05-14-2009, 11:38 PM
denzee's Avatar
Rep: denzee is just really nicedenzee is just really nicedenzee is just really nicedenzee is just really nice (361)
I think jet is right. If you're careful when disassembling the carbs, you can re-use all the parts. After all, the main culprit in carbs is blockage in the small ports. Be sure to completely disassemble, taking note of the number of turns with the air bleed screws. The used compressed air in every passage. Follow each passage and take your time and be sure each one is clear. I like to use brake cleaner after with the straw on the can to verify each passage is clear. Give it a little shot and watch where it comes out. Do that to all passages plus clean the needle valve carefully. That's the one that the float controls like a toilet tank.
denzee is offline
Old 05-17-2009, 6:16 AM
well. i dont have any compressed air. i dont even have a garage or anything. stuck doing this in my livingroom hope i dont lose anything. is there any special tools i need. this is my first time on a motorcyle. done it plenty on the mustang but not a bike
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 4:08 AM.
