VTX 1300 Dies and very tired on restart?
Old 05-27-2009, 6:02 PM
Bike(s): 02'VFR800 01'CBR929 04'VTX1300
Rep: DrRuckus07 is on a distinguished road (14)
My 04 VTX 1300 C has been dying while riding it lately and i cant find the reason. There is something either mechanically wrong or Electrically wrong with the bike that is causing this issue.
Issues:
1) dies while riding, low RPM, High RPM, Mid RPM, Witch clutch in, With clutch out, moving or sitting at Idel.
2) have drained and refilled the gas tank and went through the fuel hoses to the carb with no issues.
3) totally random, happened after a 2 hour ride and after starting.
4) once it happens takes anywhere from 1 to 20 tries to get the engine to re start
5) the engine turns but acts like there is no gas/ or air. But never smells totally flooded, but after 5 attempts of the engine spinning or so I do smell gas.
6) i ran carb cleaner through about 500 miles ago when i took it out of storage in April. No issues until one random day 2 weeks ago. had this problem ever since.
any ideas? its driving me nuts and i dont want to wait a month for the honda service department to have time to look at it in 30 days!
Please help so i can ride my cruiser again!
DrRuckus07 is offline
View DrRuckus07's Profile View DrRuckus07's Gallery Find More Posts by DrRuckus07
Old 05-27-2009, 8:59 PM
Jetpilot07's Avatar
Bike(s): 2007 CBR1000RR
Re: VTX 1300 Dies and very tired on restart?
change the plugs?
clean or replace the airfilter?
GENERAL ROBERT E. LEE
Jetpilot07 is offline
Old 05-27-2009, 10:16 PM
DUX
DUX's Avatar
Bike(s): 07 GSAdv
Rep: DUX is just really niceDUX is just really niceDUX is just really niceDUX is just really nice (383)
Take a look on the 1300 forums on VTXOA.com
You'll probably have better luck and may even find someone who has dealt with the exact problem on their VTX.
DUX is offline
View DUX's Profile View DUX's Gallery Find More Posts by DUX
Old 05-28-2009, 7:40 PM
Thank you for the responses. I will check out VTXOA and see if they have more VTX owners there.
I did change the plugs and wash the K&N air filter. But same result aftwards.
Old 05-28-2009, 11:45 PM
DUX
DUX's Avatar
Bike(s): 07 GSAdv
VTXOA is all about VTX's.
VTX Owner's Association.
DUX is offline
Old 07-03-2009, 4:02 PM
Bike(s): 2007 CBR1000RR,2004 RC51 Nicky Hayden Edition
Rep: Bigtoe is on a distinguished road (34)
I'm sure VTXOA will tell you whats up. It sounds like a ground problem though!
Bigtoe is offline
View Bigtoe's Profile View Bigtoe's Gallery Find More Posts by Bigtoe
Old 07-07-2009, 2:16 AM
Bike(s): 01 VT750 Ace
Rep: justin1.stacy is on a distinguished road (10)
im not sure if it has a electric fuel pump but i have a honda shadow and it was doing something similar to that and jumpered the fuel relay and found that it was the electric fuel pump something to look at
justin1.stacy is offline
View justin1.stacy's Profile View justin1.stacy's Gallery Find More Posts by justin1.stacy
Old 07-08-2009, 1:01 AM
Rep: kamk@telus.net is on a distinguished road (10)
Issues:
Have you had your right rear cylinder head plastic thingie-ma-gig off lately?; the breather tube is routed over the cylinder cover. It could be pinched. Happened to me. When I took the cylinder cover off ( the plastic piece that hides the rear right spark plug), I heard an air-rushing sound. After I re-routed the breather tube so that it wasn't pinched, everything worked just fine.
Kam
kamk@telus.net is offline
View kamk@telus.net's Profile View kamk@telus.net's Gallery Find More Posts by kamk@telus.net
Old 08-10-2009, 1:08 PM
Thanks everyone for your responses! I ended up having to take the bike to Honda who had it for about a month before it was fixed. It ended up being a plugged component in the carb by a piece of sand or something small. it took 3 carb cleaning to get it out. 1 cleaning by me, and 2 cleanings by the shop. Whatever was hiding in there was hard to flush out.
For the lesson Learned:
All VTX (or cruiser owners whos bikes dont have fuel filters. Go buy a cheap little aftermarke fuel filter and splice it on the fuel pipe before it reaches the carb becuase the cheap little rubber fuel screen does not do a very good job against tiny debris in the gas!
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 3:55 AM.
