stalling, cutting out at power VT750 Ace
07-01-2009, 9:08 PM
Bike(s): 01 VT750 Ace Posts: 5
| stalling, cutting out at power VT750 Ace Hi all,
I have a 2001 VT750 Ace the other day i was riding about 60 mph and got on it after a coner and it started to stall and die. It acted like i had no fuel which i had just put gas in it, got it home check the spark plugs and wires drained the carb bowl thinking there was water in it and today i drained the gas tank and there was no water in the gas tank. I dont know what else to do with it. It will run for about half way to work 10-15min then start stalling and die and i have to give it a little bit then try and start it and it will start and stay running. Today it did it 4 times on my way to work but it only died once the other 3 it kept running. Any help i would appricate it thanks |
07-01-2009, 9:21 PM
#2 | | Out Of Many, We Are One
Bike(s): CBR954RR, Hornet CB900F-5, VFR800FI + More Posts: 6,906
| Re: stalling, cutting out at power VT750 Ace Just thinking whether it is an electrical problem or fuel related...
Could it be your kill switch playing up? Not sure if there is a fuel filter connected inline which may have got clogged? (Don't think there is one but you never know).
07-01-2009, 9:24 PM
| Re: stalling, cutting out at power VT750 Ace there is a fuel filter and im going tomorrow to go and get one it idles fine its just when you give it gas to take off or get on it going around a corner im really confused on this one |
07-01-2009, 9:34 PM
#4 | | Out Of Many, We Are One
| Re: stalling, cutting out at power VT750 Ace Quote:
Originally Posted by justin1.stacy there is a fuel filter and im going tomorrow to go and get one it idles fine its just when you give it gas to take off or get on it going around a corner im really confused on this one | Does she suffer in all gears including neutral?
07-01-2009, 10:58 PM
| Re: stalling, cutting out at power VT750 Ace no she idles fine and its an intermentant problem may do it 4 times a day or not at all its getting worse im thinkiing the fuel filter and the fuel shut off screen in the tank and then go from there it does have a electric fuel pump hoping its not that |
07-07-2009, 2:13 AM
| Re: stalling, cutting out at power VT750 Ace looked at it this weekend and jumpered the fuel cutoff relay and found that the fuel pump did not come on tapped it with a hammer and it would pump for a second then stop. So it was the fuel pump have to pick it up on tuesday so hopefully it will be on the road wednesday thanks alot |
