speedometer squealing
Old 07-28-2009, 10:27 PM
Bike(s): 1983 honda v45 magna, 1983 honda xl250r
Rep: jozer is on a distinguished road (10)
my speedometer i squealing does any one know if its the cable or the speedo itself?
jozer is offline
View jozer's Profile View jozer's Gallery Find More Posts by jozer
Old 07-29-2009, 3:23 AM
ghbzorro's Avatar
Bike(s): '88 Hawk GT; '98 Blade (now sold)
Rep: ghbzorro is a jewel in the roughghbzorro is a jewel in the roughghbzorro is a jewel in the rough (260)
Re: speedometer squealing
That's an odd one.
Have you tried to somehow lubricate the cable? Was it sitting for a long tme?
ghbzorro is offline
Old 07-29-2009, 9:06 AM
Bike(s): 85 shadow vt700c
Rep: reefkprZ will become famous soon enough (67)
It could be either the cable or the actual speedo
Usually when speedo cables start squeeling they are on their way out you can try lubricating the cable with a light oil (wd 40, 3 in one, or hoppes gun oil) no gaurantees on that though.
but it could also be the gearing inside the speedometer. if thats the case the grease in the case may be drying out, there is generally a light layer of grease applied to the gearing of mechanical speedometers, often dust, grime and dirt slowly build up over the years reducing the effectiveness drying it out. if you can open the speedo case and clean the old grease out you may be able to re-grease it. BUT more often than not if the speedo itself is squealing the bearings or seats for the gears is shot and the speedo will need to be replaced, because thing are no longer aligned correctly.
the easiest way to test it is to diwconnect the speedo cable from the speedo (at the top only leave the bottom connected) put it up on its stand and put it in gear, if it still squeeks with the tire rolling its the cable, if it stops with the cable disconnected its the speedo.
reefkprZ is offline
View reefkprZ's Profile View reefkprZ's Gallery Find More Posts by reefkprZ
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 3:31 AM.
