like I said "I" am not aware of a larger tank that will bolt straight on. I have been looking around for a larger tank for my shadow 700, and every larger tank I have found has a different mounting position so far. there very well could be a good straight bolt on from one of those models you listed. the easiest way would, I guess, be to measure the mounting brakets and their positions. or do the "flip" test (take your tank and flip it belly to belly with one of those others) and see if the brackets are in the same place.
I definatly wasnt saying there isnt one that will fit. but I was saying that in my expirience the chances are fairly slim for a perfect fit without at least some modifications.
hopefuly some one may have had some first hand expirience with the models your listing and be able to chime in and tell me I'm a fool and point you in the right direction
