1983 magna 750 rear shaft drive case full of oil
Old 08-02-2009, 11:12 PM
Bike(s): 1983 honda v45 magna, 1983 honda xl250r
Rep: jozer is on a distinguished road (10)
the rear drive case is full of oil and was wondering if that would engine oil
jozer is offline
View jozer's Profile View jozer's Gallery Find More Posts by jozer
Old 08-03-2009, 12:15 AM
Jetpilot07's Avatar
Bike(s): 2007 CBR1000RR
Re: 1983 magna 750 rear shaft drive case full of oil
could possibly be a bad output shaft seal if it's pouring out the fill cap. should have enough honda hypoid gear oil to flow out the side check screw (if equipped)
GENERAL ROBERT E. LEE
Jetpilot07 is offline
Old 08-08-2009, 1:05 AM
Bike(s): 85 shadow vt700c
Rep: reefkprZ will become famous soon enough (67)
correct me if I am wrong but I believe the Original poster is asking if the oil in the gearbox is the same as engine oil.
to whit I answer, as mentioned in the first reply its hypoid gear oil DO NOT use engine oil in your gearbox. ensure that you find your manufacturers recomended hypoid gear oil rating and use only that.
there is a serious viscosity difference between the two that would lead to excessive wear and rapid deterioration of your gears. unlike your engine that has a pump to pump the oil to the top and let it wash back down over your internal motor parts, your gear box only has the lower sections of the gears resting in a bath and require a higher viscosity to transfer the oils upwards when the parts are in motion (basicly the oil sticks to the parts and gets carried upwards by the motions of the parts)
reefkprZ is offline
View reefkprZ's Profile View reefkprZ's Gallery Find More Posts by reefkprZ
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 8:21 PM.
