Seafoam anyone?
Old 09-15-2009, 2:20 PM
Bike(s): 2005 Honda Shadow Spirit VT750DC
Rep: ScrappyDo is on a distinguished road (10)
Seafoam anyone?
Has anyone ever used seafoam in their bike? Just trying to find out how it went, if it worked, problems. I have some pinging and knocking going on. I've checked everything else.
ScrappyDo is offline
View ScrappyDo's Profile View ScrappyDo's Gallery Find More Posts by ScrappyDo
Old 09-15-2009, 9:32 PM
Out Of Many, We Are One
Twincam's Avatar
Re: Seafoam anyone?
What fuel are you running? regular?
Twincam is offline
Old 09-16-2009, 1:20 AM
Re: Seafoam anyone?
Regular and then I was having problems so I ran the super, then I had more problems and I added some additives. Now I'm pretty sure that I have some carbon build up. I've replaced the fuel filter, checked the fuel valve and screen, checked the hoses, and the fuel pump. If this doesn't work, it's off to the shop.
Old 09-16-2009, 1:59 AM
Shinji43's Avatar
Bike(s): '03 CBR 954RR
Rep: Shinji43 is on a distinguished road (17)
Re: Seafoam anyone?
If you were runnin only 87 in it then that most likely was causin spark knock (pre-detonation). Bikes usually run 92+. You might need to go through a tank or two of premium to get all the lower grade out of the system...that should reduce the knock.
Shinji43 is offline
View Shinji43's Profile View Shinji43's Gallery Find More Posts by Shinji43 My Map Location
Old 09-16-2009, 5:45 PM
Re: Seafoam anyone?
When I give it any kind of gas, it stalls out. It'll idle and I can hear it knock, but you can't ride it at all.
Old 09-16-2009, 5:48 PM
Twincam's Avatar
Re: Seafoam anyone?
Is it throwing a lot of fuel out? FPR?
Twincam is offline
Old 09-16-2009, 10:52 PM
Re: Seafoam anyone?
Don't know what you mean.
Old 09-16-2009, 11:14 PM
cbr1kfireblade's Avatar
Bike(s): CBR1000rr6
Re: Seafoam anyone?
fuel in the oil, or going out the exhaust....
FPR= fuel pressure regulator
cbr1kfireblade is offline
Old 09-16-2009, 11:41 PM
Bike(s): '00 929rr
Rep: matt365 is on a distinguished road (10)
Re: Seafoam anyone?
These bikes are designed to run on 87 octane... to run any higher is throwing away money... and no I don't want to get into an octane debate.
matt365 is offline
View matt365's Profile View matt365's Gallery Find More Posts by matt365
Old 09-17-2009, 12:22 AM
Bike(s): CBR1000rr6
Re: Seafoam anyone?
im not being a smartass but where did you hear that? mine says use premium fuel ONLY..
Old 09-17-2009, 1:20 AM
Re: Seafoam anyone?
It says 86 or higher in the service manual. And no, there isn't any fuel in the oil or going out the exhaust.
Old 09-17-2009, 3:04 AM
Shinji43's Avatar
Re: Seafoam anyone?
How's the gas milage been recently? If it's been really horrible that could be another sign of a bad FPR. If it's bad it's basically flooding the engine.
Shinji43 is offline
Old 09-17-2009, 6:57 PM
Twincam's Avatar
Re: Seafoam anyone?
Pull the vacuum pipes and check for fuel (I think thats how you check it - been discussed quite a bit recently)
Twincam is offline
Old 09-18-2009, 6:44 AM
Bike(s): 85 Shadow VT 1100
Rep: Caledan is on a distinguished road (10)
Re: Seafoam anyone?
It was introduced to me when my bike stalled 5 miles after refueling with non-ethanol based fuel - tank, still had 3ths of ethanol based. Apparently the non-eth fuel knocked crap off the inside & blocked something. A bike neighbor gave me his can of Sea Foam said to follow the directions - 1 tbs per gallon, and rocked the bike "to mix" it around and I let it sit overnight. Yes it backfired a few times and was rough for about 15 min., after that it ran. Now I use it every few tanks full then go for a 50 mile ride.
Caledan is offline
View Caledan's Profile View Caledan's Gallery Find More Posts by Caledan
Old 09-18-2009, 1:44 PM
  #15
Bike(s): CBR1000rr6
Re: Seafoam anyone?
my bad just looked and seen what kind of ride you have
Old 09-18-2009, 4:54 PM
  #16
Re: Seafoam anyone?
No biggy, not riding right now - recovering from a spill. Hurt my confidence & going through my own designed physical therapy.
Caledan is offline
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 10:30 AM.
