85 vf700 float bowl gaskets. where to get. - Honda Motorcycles - FireBlades.org
Honda Cruisers Discussion of the Honda Rebel, Honda Shadow, and Honda VTX Motorcycles.
post #1 of 5 Old 09-15-2010, 10:57 AM Thread Starter
just about finished rebuilding and it actually started and ran good on first try. HOWEVER, when i pulled the carb set and cleaned them i did not use new gaskets and one is leaking. does anyone sell just the gaskets or is it possible to use formagasket on them? thanks
bobg is offline
post #2 of 5 Old 09-15-2010, 11:37 AM
Images: 2
Quoted: 2 Post(s)
Reputation Power: 227
Re: 85 vf700 float bowl gaskets. where to get.
Did you try a dealer?
Otherwise - FLOAT BOWL O-RING: HONDA VF750F
post #3 of 5 Old 09-15-2010, 11:46 AM Thread Starter
thanks blade! not been to a dealer yet. wanted to see if a website might be a good choice. thanks for the link! good on ya!
bobg is offline
post #4 of 5 Old 09-17-2010, 9:24 AM Thread Starter
WELL, I WENT OUT TO PULL THE CARB SET and after removing the tank and airbox i decided to start the bike and look close for the leak first. after 5 minutes of seeing no gas i feel that maybe one of the floats stuck on the initial starting cycle. as i have no way of knowing how long the bike sat that may have been it.
bobg is offline
post #5 of 5 Old 09-17-2010, 9:46 AM
Images: 2
Quoted: 2 Post(s)
Had exactly the same thing myself this week.
I built a DR500 engine (bad transmission) and then rebuilt the carb before putting any fuel through the fresh engine.
I turned the fuel on and it just poured straight out the carb overflow, so I turned the tap off as it looked like the carb had to come off again.
But I fired the engine up anyway first to make sure the build was good.
Then it occurred to me that perhaps running the engine might have jiggled the carb enough to close a sticking float valve. Turned the fuel back on and it's been just fine :-)
Go Back   Honda Motorcycles - FireBlades.org > Honda Motorcycle Models > Honda Cruisers
Human Verification
Search tags for this page
1985 honda shadow vt500 float bowl gasket
1985 honda shadow vt700 the carburetor float bowl gasket
85 vf700f float height
honda motorcycle, carburetor gasket, vf700
honda rebel 450 bowl gasket
how to set floats on 1985 250 honda fourtrax
setting float level on 85 honda 700 shadow
vf700f carburetor float repair
vt500 float bowl gaskets
whats the float height on vf700s carbs
vf700 engine trikeguy For Sale 0 07-05-2010 7:20 PM
'82 v45 float adjustment tapdog Honda Cruisers 0 11-01-2008 9:36 PM
Need float bowl seal/O-ring ksmutek Honda FireBlade 2 08-28-2008 2:49 AM
Float in front brake master cylinder jcblitz Honda FireBlade 4 06-23-2004 2:44 AM
