cbr 929 brake light stays on - Honda Motorcycles - FireBlades.org
post #1 of 4 Old 07-24-2012, 3:11 AM Thread Starter
just got my 2001 cbr 929 back together after complete rebuild. Everything works, except brake light is stuck on. Stock tail light, Tech G rearsets with pressure switch, new adjustable levers. I did have to rewire the plugs that connect to bulb sockets in tail light, but followed wiring diagram. Tried disconnecting rear brake pressure switch - brake light still on. Tried also disconnecting front brake switch - brake light still on when key is turned. This would seem to suggest a short somewhere, but don't know where to start. Wiring harness seems in good shape. If I mixed up the tail light and brake light leads in the connector, could that cause the problem? According to diagram, middle pin is ground, and outer 2 are tail and brake. Both filaments are lit.
rkubin999 is offline
post #2 of 4 Old 07-24-2012, 4:35 AM
Reputation Power: 22
Re: cbr 929 brake light stays on
If the lights are on with the switches disconnected, then I would guess that the wiring at the bulb isn't correct.
vfrman is offline
post #3 of 4 Old 07-24-2012, 5:09 AM
Images: 4
Reputation Power: 12
Can you turn the lights off on a 929? if so dose 1 or both go off with the main lights? guess you could pull the fuse to get the same effect.
other posibility is a short at either of the switches.
CBRR is offline
post #4 of 4 Old 07-25-2012, 1:20 AM Thread Starter
vfrman, you were right! the wiring diagram showed the ground as center pin. when I checked the voltage at connector found that ground should be right pin. rearranged accordingly and voila, every works!
Human Verification
Search tags for this page
01 cbr 929 brake light stays on
01 honda cbr 929rr brake lights staying on
2001 929 brake light staying on
929 front brake light
brake light stays on motorcycle
brake light wire 06 cbr
cbr brake light stays on
front brake light stays on cbr 954rr
honda cbr 929 brake lights stay on
show me brake lights diagram for 929 honda motor cycle
fi mil light stays on help!!!!!! comokiller Honda FireBlade 15 04-02-2011 12:40 PM
Oil light stays on Addipops Honda FireBlade 12 07-31-2010 9:25 AM
01 cbr 929 mil light stays on tunil Honda FireBlade 4 07-29-2010 3:49 AM
Brake light stays on bjay51d Honda FireBlade 12 05-16-2009 12:01 AM
Brake light stays on? EvLTwiN Honda RC51 9 05-28-2007 5:59 PM
