954 Rear Shock Removal - Honda Motorcycles - FireBlades.org
post #1 of 7 Old 04-23-2013, 4:27 PM Thread Starter
Quick question......can the rear shock be removed by just taking the rear wheel off? I have all the bolts loose waiting for it's replacement and it looks like it will slide out with the rear wheels out of the way. I still have the side cowls and exhaust in place.
modular is offline
post #2 of 7 Old 04-23-2013, 5:10 PM
Images: 2
Quoted: 2 Post(s)
Reputation Power: 227
Re: 954 Rear Shock Removal
You don't need to remove the wheel.
Support the rear subframe so the tyre is just touching the ground.
Remove the lower linkage bolt and lower shock bolt.
Remove the upper bolt.
Pull the shock out through the bottom.
post #3 of 7 Old 04-23-2013, 5:18 PM Thread Starter
Will this work with the exhaust and side cowls in place? I have the rider foot pegs flipped and will be lowering the bike down on jack stands off the rear stand.
modular is offline
post #4 of 7 Old 04-24-2013, 5:22 AM
Images: 2
Quoted: 2 Post(s)
As long as you can access the bolts I would expect it to work fine.
post #5 of 7 Old 04-24-2013, 5:26 AM Thread Starter
I already have the top bolt nut off as well as the 3 lower link nuts. Just waiting for the replacement shock. I hope it ends up being this easy.
modular is offline
post #6 of 7 Old 04-24-2013, 5:28 AM
Images: 2
Quoted: 2 Post(s)
Are you replacing it with another OEM shock or something aftermarket?
post #7 of 7 Old 04-24-2013, 5:30 AM Thread Starter
It's a low mileage OEM take-off. The compression adjuster is frozen on my current one.
modular is offline
Human Verification
Search tags for this page
2003 954rr rear shock removal
cbr 954 rear linkage removal
cbr954 rear shock
fireblade rear shock
954 Rear Shock Removal/Install vospertw Honda FireBlade 11 08-05-2011 1:35 PM
Rear shock and spring removal speed918 Honda FireBlade 1 02-19-2011 12:05 PM
Fork and shock removal help jlag Honda FireBlade 9 01-21-2009 5:37 PM
Rear Shock removal... RLJ10X Honda FireBlade 6 07-03-2006 2:38 AM
Rear shock Removal l'timbré Honda FireBlade 5 04-19-2004 8:27 AM
