Honda Motorcycles
Navigation » Honda Motorcycles - FireBlades.org > Honda Motorcycle Models > Honda FireBlade » CBR 929 Fork oil weight?
Old 03-18-2004, 11:46 PM   #1
prkiller is on a distinguished road
Just like the topic says, what weight is called for with the 929 fork oil?
Anyone have recommendations for something other than stock?
prkiller is offline   Reply With Quote
Old 03-19-2004, 3:01 AM   #2
Reputation Power: 7
2bitsamile is on a distinguished road
Re: CBR 929 Fork oil weight?
assuming you have stock springs:
5wt for lighter rider
7wt for heavier rider
10wt if you want the crap knocked out of you
stock amount is 490cc. Use less if you want less progressive spring rate, especially if you're a lighter rider. Use more oil if you're using too much travel or bottoming. The 929 spring has a progressive rate: starts at ~.7kg/mm and ends at ~1kg/mm fully compressed.
2bitsamile is offline   Reply With Quote
Old 12-02-2009, 5:50 AM   #3
kpavey is on a distinguished road
Re: CBR 929RR Rear Spring Specs?
Anyone know the CBR929RR rear spring diameter ID and OD, and free length and coil thickness by chance?
kpavey is offline   Reply With Quote
Visitors found this page by searching for these keywords:
honda cbr fork oil
cbr 900 fork level
cbr 929 fork oil
paintcodes honda cbr900rrw 1999
what weight is honda fork fluid
You may not post new threads
You may not post replies
[IMG] code is Off
what weight rider are the stock springs set up for n.e.o. rider General Discussion 18 03-06-2004 3:33 PM
Will the oil filter from a CBR 900 1999 fit a CBR 929 2000 ? chaosExpanding Honda FireBlade 7 03-05-2004 3:31 PM
929 early oil change recommendations Mavic Honda FireBlade 1 05-28-2003 4:26 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98
