What is the easiest way to remove bad gas? - Honda Motorcycles - FireBlades.org
post #1 of 4 Old 03-22-2004, 2:05 AM Thread Starter
Send a message via Yahoo to Bdonkadonk74
I think my problem is bad gas which in turn has fouled my plugs and i've drained the tank but i'm trying to figure out if I can get more of that crappy fuel outta my system. Any suggestions?
Bdonkadonk74 is offline
post #2 of 4 Old 03-22-2004, 2:17 AM
NinerPilot's Avatar
Images: 17
Reputation Power: 22
Re: What is the easiest way to remove bad gas?
Siphon out as much as possible with some tubing, then lift the front of the tank and unhook the hose from the outlet that points to the right of the bike. Have another tube ready to slip over this to catch the gas as it somes out. If you arent inclined to take the tank up, as long as you get the majority of the old gas out and fill it with fresh, you should be ok.
Chris
NinerPilot is offline
post #3 of 4 Old 03-22-2004, 3:31 AM
Reputation Power: 17
Since you have already drained the tank, pull the fuel line off at the fuel rail behind the throttle bodies. This will allow you to drain even more from the tank, and drain the fuel rail. Since this is what feeds the injectors, if you can get as much fuel out of it as possible ( lean it to the right with the end open ) it shouldn't take long to get the last of it through the injectors.
Just be carefull when takin the cap off of the fuel rail, use two wrenches to make sure you don't twist the rail.
Keith
ps, can you ship me back a Donor Kepap. They used to have a great little shop in downtown Darmstadt.
Keith_929 is offline
post #4 of 4 Old 03-22-2004, 5:20 AM Thread Starter
Keith
I really appreciate the advice and i will try it. And there is a great kebap stand right next the Irish Pub here and they are great after a night of drinking. Thanks alot for the input.
Human Verification
Out of the cage kitty......Oh bad kitty, bad kitty!!!! Mavic Off-Topic 3 02-07-2004 6:47 PM
Bad gas, must of ate something... fl-929 Off-Topic 3 01-29-2004 9:20 PM
Don't gas up at 76/Conoco? Now you just might. 2OHOH2 Off-Topic 2 12-12-2003 8:39 AM
bad radiator cap? ilikesilver Honda FireBlade 2 06-19-2003 9:26 AM
Getting out of bad headshake/tankslappers RRWANTR Honda FireBlade 11 06-12-2003 10:25 AM
