Brake light switch 2004-2007 CBR1000RR Rearsets - Honda Motorcycles - FireBlades.org
post #1 of 11 Old 09-18-2016, 10:51 AM Thread Starter
Quoted: 127 Post(s)
Reputation Power: 2
My new rearsets claim that the stock switch is usable and there is a bracket. I seem to have run into a problem with the length of the wiring harness. It seems to be routed toward the front of the bike but I haven't taken the fairing off to be sure. I need more slack and usually there is a cable tie somewhere, I hope.
Has anyone used the stock brake light switch and run into the same issue? Yes, I know I can use a banjo pressure switch and that's what I did for my F4i, but I'm being insistent :-)
-2006 CBR1000RR- Jardine RT-1 CF, GP Shift rearsets, GP Suspensions 20mm revalve, Penske 8987 triple clicker
-2002 CBR600F4i (was mine and now hers)
Ohlins, Racetech, Showa custom Suspension
Jaybird180 is offline
post #2 of 11 Old 09-19-2016, 4:57 PM
RRDemon's Avatar
Quoted: 76 Post(s)
Reputation Power: 62
Re: Brake light switch 2004-2007 CBR1000RR Rearsets
I have a banjo-pressure unit for mine (only option ProTek gives).... but the harness is backwards than what the loom requires to connect it back into the bike's elec.system lol.
I know the 04-07 and 954's tail harness is fairly close.. not sure about the rest- but the tail is very similar...
The switch connection should run on the right side of your subframe (outside/under) and connect about 5 or 6 inches behind the rearsets.... The rest of the loom runs up from the switch/master and once up-to-level it reverts rearward toward the taillight.
As for adding length.... splicing always works- or even a full re-wire if you're handy with a soldering iron.
RRDemon is offline
post #3 of 11 Old 09-19-2016, 5:26 PM Thread Starter
Quoted: 127 Post(s)
Reputation Power: 2
...except it looks like it goes toward the front of the motorcycle (scratching head).
post #4 of 11 Old 09-19-2016, 5:45 PM
RRDemon's Avatar
Quoted: 76 Post(s)
Hrm... perhaps there are bigger differences than I remember when comparing them.... off to go search =P
RRDemon is offline
post #5 of 11 Old 09-19-2016, 9:36 PM Thread Starter
Quoted: 127 Post(s)
Reputation Power: 2
I am resolved to announce that it's just not gonna work. Not enough slack in the line. I disconnected the switch but it's still in place until I replace it. I'm ready for a test ride (short one) before I loctite everything down. The wiring upstream doesn't look factory with electrical tape around it. No way to know if it would have worked after all. Now I just have to decide what type of switch I'm going to procure.
I've fooled around with this upgrade far too long. I'm glad it's done (almost).
post #6 of 11 Old 09-19-2016, 10:02 PM
Quoted: 145 Post(s)
Reputation Power: 23
Don't be fooled by electrical tape thinking that Honda didn't use it.
lanbrown is offline
post #7 of 11 Old 09-19-2016, 11:33 PM Thread Starter
Quoted: 127 Post(s)
Reputation Power: 2
It is a pretty tight installation. Just surprising to see that; I guess it's more weight for a racer to remove and pat himself on the back.
post #8 of 11 Old 09-19-2016, 11:37 PM Thread Starter
Quoted: 127 Post(s)
Reputation Power: 2
Test ride is done. I need to lower the brake side. The shifter side was functioning well but the lever dropped on me as the shift rod unwound (something's gotta break on a test ride, right?). Fortunately the ride was short and I didn't lose the rod.
The position is more aggressive than I expected and I'm going to see if Incan relax it a bit, too far back but not uncomfortable. If not, I think it's going to work fine once I get the stomp grips in place.
post #9 of 11 Old 09-19-2016, 11:46 PM
RRDemon's Avatar
Quoted: 76 Post(s)
I do not run a rear brake light switch at all... I trail brake into corners far too often and it throws off the people behind me as to why I am braking so far into the corner lol.. I just left it missing and called it a day when I installed my ProTek rearsets... it did come with a pressure-banjo type though.
RRDemon is offline
post #10 of 11 Old 09-20-2016, 1:41 PM Thread Starter
Quoted: 127 Post(s)
Reputation Power: 2
I've heard of trailing the front into the corner but never thought of doing it with the rear. I've used the rear for tightening a line on off-camber or double apex corners. Your use is certainly unique. I feel that if I need to do that on the street either I screwed up the corner speed/entry line, which I'm prone to do from time to time or I'm clowning around and experimenting (also prone to do time-time).
post #11 of 11 Old 04-19-2017, 12:33 PM Thread Starter
Quoted: 127 Post(s)
Reputation Power: 2
Happened across this old thread O' mine. The banjo switch is in place, but I need to remember to get to the hardware store for electrical fittings and/or a length of wiring, damn thing is just a hair too short.
Human Verification
Photo request- 2004-2007 CBR1000RR stock Rearsets Jaybird180 Honda FireBlade 1 09-20-2016 12:28 AM
Cbr1000rr 2004 brake light Rutkowski35 General Discussion 22 03-05-2012 3:49 PM
WTB: Rear brake light switch DrSavant Wanted 0 04-26-2011 6:54 PM
I need a rear brake light switch!Please help krazy900rr Wanted 4 02-17-2009 7:07 PM
Sato Brake Light Switch Creeper Honda RC51 3 04-04-2005 1:28 PM
