Slow cranking/hard to start - Honda Motorcycles - FireBlades.org
 3Likes
  • 1 Post By lanbrown
  • 1 Post By jondog9
  • 1 Post By Hawkes
post #1 of 12 Old 03-04-2017, 9:11 AM Thread Starter
Reputation Power: 8
Hi Everyone
I recently picked up an 03 954, runs nice, idles lovely. The problem is starting it.
Instead of cranking at the usual speed of most bikes, this one cranks slowly, like it would with a low
voltage battery. However the battery has a good 12.5 volts standing and the idle is 14.5, everything seems
normal there.
Can anyone point me in the right direction as to where to start looking next?
Thanks
Hawkes is offline
post #2 of 12 Old 03-04-2017, 10:50 AM
Quoted: 174 Post(s)
Reputation Power: 23
Re: Slow cranking/hard to start
I would still check the battery. Voltage only plays a part, what happens when it is under load? I've seen batteries test good but fail when put under a load. If it isn't the battery, then it is either wiring or the starter.
IanDoohan likes this.
lanbrown is online now
post #3 of 12 Old 03-04-2017, 4:25 PM
Gunk's Avatar
Images: 8
Quoted: 175 Post(s)
Reputation Power: 10
I agree with Ian 90% of the time it's just a duff battery
Gunk is online now
post #4 of 12 Old 03-05-2017, 6:46 PM
Greenie
jondog9's Avatar
Images: 1
Quoted: 42 Post(s)
Reputation Power: 181
First thought was it might be a dragging starter.
But, first things first:
How old is the battery, and what voltage does it dip to when you thumb the starter?
Also, what size is it? I believe the 954 calls for a yuasa 10s (or equivalent) or better.
Some guys will use a smaller battery for weight concerns, or trackdays. If you have a 8s, or something smaller with less cold cranking amperage, that could explain it too.
Joe929 likes this.
jondog9 is offline
post #5 of 12 Old 03-06-2017, 3:04 AM
Quoted: 21 Post(s)
Easy way to test batt cranking power is jump it off your car, how does it start then? BTW no need to start car, jump leads with car engine off.
Spaz is offline
post #6 of 12 Old 03-12-2017, 10:00 AM Thread Starter
Reputation Power: 8
Hi people
So, the battery voltage goes to 9.50 ish when cranking which is too low, tested a new battery and is 10.50 ish whilst cranking, and sounds normal now.
So I tested the charge, tested the resting voltage but failed to test it whilst cranking which revealed the dud battery. Fail on my part.
Anyway, thanks for your help and suggestions in helping me crack that.
Happy and safe riding.
jondog9 likes this.
Hawkes is offline
post #7 of 12 Old 03-18-2017, 9:20 PM
Greenie
jondog9's Avatar
Images: 1
Quoted: 42 Post(s)
Sounds like a happy ending.
jondog9 is offline
post #8 of 12 Old 03-19-2017, 12:40 PM
Quoted: 11 Post(s)
I am still having this problem on my bike same bike and year I have already changed the battery but I put a powerline in it and still not made a difference. Which battery did our put in please?
Rabmccall is offline
post #9 of 12 Old 03-20-2017, 4:48 AM
oldbastard's Avatar
Quoted: 20 Post(s)
Reputation Power: 9
Forgive the slight highjack, but has anyone yet had experience of using Lithium batteries to replace lead/acid on the 929 or 954?
oldbastard is offline
post #10 of 12 Old 03-20-2017, 7:42 AM
Reputation Power: 5
@oldbastard - Been using a Shorai in my 954RR for the past couple of years without any problems whatsoever. Happy customer here.
-'02 Silver/Black CBR 954RR
-'06 Black/Metallic Gray RC-51
-'11 Graphite Black CBR 1000RR
(sold)
-'08 Pearl Orange CBR 600RR (sold)
COBRA90GT is offline
post #11 of 12 Old 03-20-2017, 9:57 AM
Quoted: 174 Post(s)
I've used the EarthX brand in a number of bikes, XX, RC51 and the RR. The nice feature with the EarthX, when the voltage drops too low, it will shut itself off. To reactivate it, all it needs to do is sense 12 volts coming in. This prevents the battery from draining completely and killing itself.
post #12 of 12 Old 03-20-2017, 1:00 PM Thread Starter
Reputation Power: 8
Honda CBR929 CBR954 Fireblade Motobatt Maintenance Free Battery 20% Extra Power | eBay
But any new battery should fix the problem, if the problem is indeed the battery. Before buying another one I would go through the manual to test the battery and such first
Hawkes is offline
Human Verification
Slow start. CBR1000RR 2013 SamCBR1K Honda FireBlade 6 12-21-2014 10:44 AM
Slow to start jud Honda FireBlade 6 10-15-2012 1:24 PM
1999 Fireblade hard start, now wont start.... MFB_87 Honda FireBlade 15 03-18-2010 11:58 PM
900rr hard to start pajazo Honda FireBlade 24 06-03-2007 10:07 PM
Slow start up Lucky929er Off-Topic 3 06-28-2004 9:11 AM
