Cbr954rr will crank no start - Honda Motorcycles - FireBlades.org
post #1 of 23 Old 03-12-2017, 4:18 PM
Rgoodell
Guest
Posts: n/a
Quoted: 6 Post(s)
I have a 954rr that has been running good, no mods other then slip on and is a mint bike. 18k miles and about a month ago had new plugs and oil, compression checked and the valve clearances checked... all were great I brought home and put new plastics on and tank to finish it.. rode it around couple days and parked it... my brother comes over last night and I show him the bike and start it ran just fine. Then I go to start it up today and wouldn't run at all. Turn the key everything is on... turn on switch and the fuel pump primes and just doesn't start. Like no spark... it just ran last night!! Wth has happened since. Can any one help a brother out. It just crank and doesn't start but does occasionally pop and try to start for a quick second.
post #2 of 23 Old 03-12-2017, 4:19 PM
Gunk's Avatar
Images: 8
Quoted: 175 Post(s)
Reputation Power: 10
Re: Cbr954rr will crank no start
Flat battery?
Gunk is online now
post #3 of 23 Old 03-12-2017, 5:23 PM
Rgoodell
Guest
Posts: n/a
Quoted: 6 Post(s)
battery is new and is running off jump cables also so it dont drain
post #4 of 23 Old 03-12-2017, 5:46 PM
Quoted: 174 Post(s)
Reputation Power: 23
When you started it last, did you just start it rev it a few times and then turn it off?
lanbrown is online now
post #5 of 23 Old 03-13-2017, 12:27 AM
Rgoodell
Guest
Posts: n/a
Quoted: 6 Post(s)
yes
post #6 of 23 Old 03-13-2017, 12:58 AM
Quoted: 174 Post(s)
Very hard on an engine and plugs. Better go and check and/or replace the plugs. Chances are, you fouled at least one plug.
post #7 of 23 Old 03-13-2017, 2:47 AM
Rgoodell
Guest
Posts: n/a
Quoted: 6 Post(s)
idk bout that never had any issues in the past doing it. plus these are brand new platinum plugs.. what would randomly cause no spark? it ran the day before and now it doesnt even start
post #8 of 23 Old 03-13-2017, 3:06 AM
Bikelifesinceth
Guest
Posts: n/a
Originally Posted by Rgoodell View Post
yes
Gotta let her warm up brotha!!
post #9 of 23 Old 03-13-2017, 3:07 AM
Bikelifesinceth
Guest
Posts: n/a
post #10 of 23 Old 03-13-2017, 9:36 AM
Heeza Y Zasch
unslow1's Avatar
Quoted: 218 Post(s)
Reputation Power: 41
Does it "poot" or "pop" while attempting to start?
unslow1 is offline
post #11 of 23 Old 03-13-2017, 9:58 AM
Quoted: 174 Post(s)
idk bout that never had any issues in the past doing it. plus these are brand new platinum plugs.. what would randomly cause no spark? it ran the day before and now it doesn't even start
Just because you haven't had an issue in the past doesn't mean anything. You abuse your equipment, it will abuse your wallet.
What does new plugs have to do with anything. You can foul new plugs just like old plugs. Do you know how plugs get fouled? Most common is too much fuel.
When you first start a gasoline engine either carbed or FI, extra fuel is put into the engine to help it warmup quicker. Then you rev it which is putting even more fuel in the engine. Not good on the engine, not good for the plugs.
How do you know you have no spark? Have you pulled the plugs and checked? If not, then you are just guessing.
post #12 of 23 Old 03-13-2017, 11:46 AM
Rgoodell
Guest
Posts: n/a
Quoted: 6 Post(s)
o guess im guessing but thats next. it will very randomly actualy run for a second but sounds like wrong firong order or something maybe bad plug like your saying. whats easiest way to get to plugs?
post #13 of 23 Old 03-13-2017, 11:59 AM
Rgoodell
Guest
Posts: n/a
Quoted: 6 Post(s)
just tried to start nothing..it was making thepoot sound and smelled of gas. some smoke black i think. ill try new plugs. how can i get to them
post #14 of 23 Old 03-13-2017, 12:33 PM
Heeza Y Zasch
unslow1's Avatar
Quoted: 218 Post(s)
spitballing: fouled plug(s), bad coil(s), low compression.
unslow1 is offline
post #15 of 23 Old 03-13-2017, 4:41 PM
If you are smelling fuel it may be flooded, try starting it with the throttle held wide open.
clayshooter is offline
Human Verification
CBR954RR Rebuild: Need Help with Crank/Rod/Case Codes levantine Streetfighter 3 02-04-2016 10:35 AM
Crank but no start 4wdforlife Honda RC51 6 07-26-2014 2:28 PM
02 cbr 954 will crank but not start?!? BrandonP954 Honda FireBlade 14 04-26-2013 7:25 PM
Cbr954rr 170 crank hp build Kratosftw Honda FireBlade 8 09-05-2012 8:12 AM
2001 CBR929 wont crank or start bladerunner2001 Honda FireBlade 5 09-14-2011 11:09 AM
