2008 1000rr fork revalve? - Honda Motorcycles - FireBlades.org
post #1 of 5 Old 05-18-2017, 6:11 AM Thread Starter
My 08 forks are in need of a revalve. Ive had a search on here and cant find anything but Im not good at such things.
Has anyone revalved there own forks? Mine have on small bump compliance and are very stiff in high speed comp. Was thinking of drilling a 1mm hole in the cart to help both issues but I have not seen one of these carts out of the fork.
The 1mm hole bypass trick was one we used on the 20mm carts out of Superhawks and Bandits.
NZSpokes is offline
post #2 of 5 Old 05-18-2017, 3:40 PM
Quoted: 127 Post(s)
Reputation Power: 2
Re: 2008 1000rr fork revalve?
I did my 2006
-2006 CBR1000RR- Jardine RT-1 CF, GP Shift rearsets, GP Suspensions 20mm revalve, Penske 8987 triple clicker
-2002 CBR600F4i (was mine and now hers)
Ohlins, Racetech, Showa custom Suspension
Jaybird180 is offline
post #3 of 5 Old 05-19-2017, 5:11 AM Thread Starter
I found this wee gem that explains a lot to me.
Peter Verdone Designs - 2005 CBR600RR Fork
NZSpokes is offline
post #4 of 5 Old 05-19-2017, 11:48 AM
Quoted: 127 Post(s)
Reputation Power: 2
I will have to read that later but I did run into issues caused by the top out springs.
post #5 of 5 Old 05-19-2017, 3:42 PM Thread Starter
The oil lock explains my lack of travel. Will get into the fork next weekend.
Current thoughts are is remove a big shim on the comp, drill a 1mm bleed in the cart and remove the oil lock.
NZSpokes is offline
Human Verification
2008 CBR1000rr Fork Spring Replacement cb200t Honda FireBlade 0 02-16-2015 10:37 PM
2008 CBR1000RR Left Fork hershey04 General Discussion 3 05-27-2013 7:07 AM
Fork settings 2008->2010 bike? Stuza Honda FireBlade 2 05-12-2011 9:01 AM
Rear Shock Revalve for the PROS? - READ THIS Tank69 Honda FireBlade 2 09-25-2003 2:00 AM
Stock shock rebuild/revalve Voodoo954 Honda FireBlade 3 09-24-2003 9:21 AM
